I have several parts done in part design WB (I make a part and create in it a body).
I set he shape color to something which is not the default grey
I import it t A2Plus and it appears grey - I have to set the color again in A2Plus.
Is this normal? I htought the color was an attribute attched to the part/body/surface and expected it to stay as set in the part \design WB
shape color is gone when using in A2Plus
Re: shape color is gone when using in A2Plus
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
You may be right.
I now created another part and it went OK.
If I will get to a part that displays this problem I will upload it.
OK, here is one. Under Design part it should appear with some red faces and some default grey faces.
At first I made it with default grey for th whole thing and put it inside a A2+ file.
Then I went back to Desigh PArt and changed the color of some faces to red, updtaed the part but it did not update.
I deleted it, saved the file, reopened the file and imported again - again it came in default grey.
Uploaded the whole assembly file (MA.....) and the probelmatic part (ME...)
- ME_Minimill_Base.FCStd
- (49.81 KiB) Downloaded 49 times
- MA_Minimill_Full.FCStd
- (54.89 KiB) Downloaded 57 times
I think I found the problem, and do not know if there is a solution to it.
In Design part - if I mark the body and give it red color (the whole body) then it will go into A2+ OK.
However, if I want to only set the color of several faces, this cannot be done when you highlight the body branch, you must go into the pad/pocket etc branch and use the "set colors..." option, but this still leaves the whole shape color as default.
So I guess that A2+ refers only to te shape color and not to the color of the separate faces
Could it be that the colours of step files are gone when importing directly with a2plus?
If I import a step file into a FcStd file the colours are there, so I guess if I'd import the FcStd file the colours would be there.
weird I imported another step file and the color is now also there.
The only difference was that with the first file that I imported the step file into another FcStd project first and afterwards into the a2plus project.
