A2plus incosistent DOF
Ben Jammin
Postby Ben Jammin » Tue Apr 14, 2020 5:55 pm
Hi Freecad users,
I am using A2plus v0.4.46b and I noticed something which I don't understand. Here is what I did :
first I set 2 planes constraints between blue part and the green part therefore I get as expected one DOF
then I add another part which I fixed to the green part with an circular constraint (rotation unlocked) and I noticed that now, green part and blue part are fixed to each other (DOF=0).
how is that possible ?
OS: Ubuntu 16.04.6 LTS
Version: 0.18.4.
Python version: 2.7.12
Locale: French/France (fr_FR)
Ben Jammin
Re: A2plus incosistent DOF
Postby Ben Jammin » Tue Apr 21, 2020 9:41 am
was my question dumb ? did I misunderstand the A2plus workbench principle ?
dan-miel
Postby dan-miel » Wed Apr 22, 2020 5:59 pm
I'm not sure if the assembly is correct. Your tree indentation looks different than the indentations that I have in my assemblies. I'm not sure why that is. Would you post your file?
Dan Miel
Pic for Ben.JPG (30.24 KiB) Viewed 169 times
Ben Jammin
Postby Ben Jammin » Fri May 22, 2020 4:55 pm
You are right, the circular constraint was supposed to appear in the construction tree. I just re-opened the freecad model and even though the tree indentation is correct (i.e. circular constraint was there) I still get the same DOF.
As you suggested I joined, the freecad model.
assemblage.FCStd
(316.37 KiB) Downloaded 4 times
