I modified the “a2p_solversystem.py” file so when a constraint conflict is found the constraint name and the part name is reported in the error message, and since I usually close the popup and cannot remember the name, it is also written to the Report view so I can look at it there.
Also the list of unmoved parts is written to the Report view window.
I have attached the “a2p_solversystem.py” file that I modified for the latest version, A2plus V0,4,46c. If you have it loaded simply rename your file to a2p_solversystem.pybak and copy this one in its place. Otherwise modify your file to include the following. Of course the line numbers will be different.
Kbwbe: I think this or something like it would be good if added to A2plus. What are your thoughts?
Lines added or modified:
Line 88
self.brokenconstraint ="" # added to store constrant name
Line 171
self.brokenconstraint = str(c.Label) #added to read broken constraint name
Line 495
print('\nCheck this constraint for error ' + self.brokenconstraint) #Added to print names to Report view
501, 502, 503 is modified
The constraint name has also been printed to Repoert view
The constraint name and part name causing conflict with last constraint is:
''' + self.brokenconstraint #Added line 501,502 then on 503 then added " + self.brokenconstraint" after '''
Line 518
print('Not moved ' + obj.Name) #added to print unmoved part names to Report View
One minute video on viewing constraints.
My A2+ tells which constraint errored. Kbwbe please look.
- a2p_solversystem.py
- (29.94 KiB) Downloaded 24 times
- Constraint name in report View.JPG (23.42 KiB) Viewed 849 times
- Popup for error.JPG (20.23 KiB) Viewed 849 times
