testing with Assembly4's "Import Datum" command, it happens that FC 0.19 crashes when you save the assembly file if you have changed the name of the imported Datum.
Here are the steps to reproduce the problem:
1) open the Assembly.FCStd file attached;
2) switch to Assembly4 WB;
3) in the model tree expand the "test" link;
4) right click on "LCS_1", in the menu click on "Assembly > Import Datum object".
5) in the field "Enter the imported Datum's name" change LCS_1 to LCS_1_abcd and click "OK";
6) Save (Ctrl-S);
7) in the "Save dependent files" window, click on Yes ---> FC crash immediately!
I did many tests to try to understand if the cause is in the length of the string or in the type of characters used, and I got the following (contradictory) results:
imported Datum's name --> Result after Ctrl-S and Save dependent files
LCS_1_ab --> Crash
LCS_1_a --> Ok
LCS_1_23 --> Crash
LCS_1abc --> Crash
LCS_1234 --> Crash
LCS12345 --> Crash
LC123456 --> Crash
L1234567 --> Crash
L123456 --> OK
abcdefgh --> Crash
so it seemed like the problem was the string length was longer than 7 characters, but...
abcdefg --> Crash
I repeat 3 times the test with the name abcdefg and I get it:
abcdefg --> Ok/Ok/Ok !!
Then I decide to do several tests for each name (closing and restarting FC each time in order to always start in the same initial conditions), getting the following results:
abcdef --> Ok/Ok/Ok
abcde --> Ok/Ok/Ok
abcd --> Crash/Crash/Crash/Ok/Crash (very strange, I decide to do 5 tests for each name...)
abc --> Crash/Crash/Crash/Crash/Crash
ABC --> Crash/Crash/Crash/Crash/Crash
LCS --> Crash/Crash/Crash/Crash/Crash
LC --> Crash/Crash/Crash/Crash/Crash
L --> Crash/Crash/Crash/Crash/Crash
LCS_ --> Crash/Crash/Crash/Crash/Crash
leaving the default LCS_1 name unchanged, everything is fine:
LCS_1 --> Ok/Ok/Ok/Ok/Ok
even in the following cases all is well:
LCS_2 --> Ok/Ok/Ok/Ok/Ok
LCS_a --> Ok/Ok/Ok/Ok/Ok
I saw here https://forum.freecadweb.org/viewtopic. ... 70#p403460 that the learner user used the name LCS_TopCorner and I wanted to do this test as well:
LCS_TopCorner --> Crash/Crash/Ok/Crash/Ok (!?!?!)
Here's the log when everything is Ok:
Msg: FreeCAD 0.19, Libs: 0.19R21125 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Log: Time = Fri May 29 15:37:52 2020
Log: AppDataSkipVendor = true
Log: AppHomePath = /tmp/.mount_FreeCA7ggUBm/usr/
Log: AppIcon = freecad
Log: AppTempPath = /tmp/
Log: BinPath = /tmp/.mount_FreeCA7ggUBm/usr/bin/
Log: BuildRepositoryURL = /home/conda/feedstock_root/build_artifacts/git_cache/github.com/FreeCAD/FreeCAD master
Log: BuildRevision = 21125 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2020/05/19 11:58:46
Log: BuildRevisionHash = 40600a55c2fe71ff589be677f6e427ccc937d003
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 19
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
Log: Debug = 0
Log: DocPath = /tmp/.mount_FreeCA7ggUBm/usr/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.19
Log: LoggingConsole = 1
Log: LoggingFile = 1
Log: LoggingFileName = /home/test/.FreeCAD/FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
Log: PYTHONHOME = /tmp/.mount_FreeCA7ggUBm/usr
Log: PYTHONPATH =
Log: PythonSearchPath = /tmp/.mount_FreeCA7ggUBm/usr/lib/python38.zip:/tmp/.mount_FreeCA7ggUBm/usr/lib/python3.8:/tmp/.mount_FreeCA7ggUBm/usr/lib/python3.8/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /home/test/.FreeCAD/system.cfg
Log: UserAppData = /home/test/.FreeCAD/
Log: UserHomePath = /home/test
Log: UserParameter = /home/test/.FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/AddonManager... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Arch... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Complete... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Draft... done
Log: Drawing became obsolete in 0.17; consider using TechDraw instead.
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Drawing... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Fem... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Idf... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Image... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Import... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Inspection... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Material... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Measure... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Mesh... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/MeshPart... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/OpenSCAD... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Part... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/PartDesign... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Path... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Points... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Raytracing... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/ReverseEngineering... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Robot... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Show(Init.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Sketcher... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Spreadsheet... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Start... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Surface... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/TechDraw... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Test... done
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Tux(Init.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Web... done
Log: Init: Initializing /home/test/.FreeCAD/Mod/fasteners... done
Log: Init: Initializing /home/test/.FreeCAD/Mod/Assembly4... done
Log: Init: Initializing /home/test/.FreeCAD/Mod/Manipulator... done
Log: Init: Initializing /home/test/.FreeCAD/Mod/BOLTSFC(Init.py not found)... ignore
Log: Init: Initializing /home/test/.FreeCAD/Mod/kicadStepUpMod... done
Log: Init: Initializing /home/test/.FreeCAD/Mod/dodo... done
Log: Init: Initializing freecad.asm3
Log: Init: No init module found in freecad.asm3, skipping
Log: Using /tmp/.mount_FreeCA7ggUBm/usr/Mod as module path!
Log: System path after init:
Log: /tmp/.mount_FreeCA7ggUBm/usr/bin
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/AddonManager
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Arch
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Complete
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Draft
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Drawing
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Fem
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Idf
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Image
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Import
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Inspection
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Material
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Measure
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Mesh
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/MeshPart
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/OpenSCAD
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Part
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/PartDesign
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Path
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Points
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Raytracing
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/ReverseEngineering
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Robot
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Show
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Sketcher
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Spreadsheet
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Start
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Surface
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/TechDraw
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Test
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Tux
Log: /tmp/.mount_FreeCA7ggUBm/usr/Mod/Web
Log: /home/test/.FreeCAD/Mod/fasteners
Log: /home/test/.FreeCAD/Mod/Assembly4
Log: /home/test/.FreeCAD/Mod/Manipulator
Log: /home/test/.FreeCAD/Mod/BOLTSFC
Log: /home/test/.FreeCAD/Mod/kicadStepUpMod
Log: /home/test/.FreeCAD/Mod/dodo
Log: /usr/local/sbin
Log: /usr/local/bin
Log: /usr/sbin
Log: /usr/bin
Log: /sbin
Log: /bin
Log: /usr/games
Log: /usr/local/games
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 3.0 (3.0 Mesa 19.2.8)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Idf(InitGui.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Measure(InitGui.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Show(InitGui.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCA7ggUBm/usr/Mod/Tux... done
Log: Module: Part
Log: Loading Part module... done
Log: Init: Initializing /home/test/.FreeCAD/Mod/BOLTSFC(InitGui.py not found)... ignore
Log: Loading Sketcher module... done
Wrn: A3 available
Log: Loading Path module... done
Log: Loading PathStock... done
Log: Loading PathToolControllerGui... done
Log: Loading PathToolController... done
Log: Init: Initializing freecad.asm3... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading PartDesign module... done
Log: Loading GUI of Part module... done
Log: Loading GUI of Sketcher module... done
Log: Loading GUI of PartDesign module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: Couldn't connect to spacenav daemon
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: QLayout: Attempting to add QLayout "" to addVariable "", which already has a layout
Log: QLayout: Attempting to add QLayout "" to animateVariable "", which already has a layout
Log: QLayout: Attempting to add QLayout "" to Asm4Help "", which already has a layout
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: Couldn't disconnect from spacenav daemon
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
Log: Time = Fri May 29 15:32:24 2020
Log: AppHomePath = /tmp/.mount_FreeCASqqWmW/usr/
Log: BinPath = /tmp/.mount_FreeCASqqWmW/usr/bin/
Log: Console = 0
Log: Debug = 0
Log: DocPath = /tmp/.mount_FreeCASqqWmW/usr/doc/
Log: PYTHONHOME = /tmp/.mount_FreeCASqqWmW/usr
Log: PYTHONPATH =
Log: PythonSearchPath = /tmp/.mount_FreeCASqqWmW/usr/lib/python38.zip:/tmp/.mount_FreeCASqqWmW/usr/lib/python3.8:/tmp/.mount_FreeCASqqWmW/usr/lib/python3.8/lib-dynload
Log: RunMode = Gui
Log: Verbose =
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/AddonManager... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Arch... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Complete... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Draft... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Drawing... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Fem... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Idf... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Image... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Import... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Inspection... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Material... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Measure... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Mesh... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/MeshPart... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/OpenSCAD... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Part... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/PartDesign... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Path... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Points... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Raytracing... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/ReverseEngineering... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Robot... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Show(Init.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Sketcher... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Spreadsheet... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Start... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Surface... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/TechDraw... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Test... done
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Tux(Init.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Web... done
Log: Using /tmp/.mount_FreeCASqqWmW/usr/Mod as module path!
Log: /tmp/.mount_FreeCASqqWmW/usr/bin
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/AddonManager
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Arch
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Complete
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Draft
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Drawing
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Fem
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Idf
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Image
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Import
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Inspection
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Material
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Measure
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Mesh
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/MeshPart
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/OpenSCAD
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Part
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/PartDesign
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Path
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Points
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Raytracing
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/ReverseEngineering
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Robot
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Show
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Sketcher
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Spreadsheet
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Start
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Surface
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/TechDraw
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Test
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Tux
Log: /tmp/.mount_FreeCASqqWmW/usr/Mod/Web
Log: /usr/local/bin
Log: /usr/sbin
Log: /usr/bin
Log: /sbin
Log: /bin
Log: /usr/games
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Idf(InitGui.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Measure(InitGui.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Show(InitGui.py not found)... ignore
Log: Init: Initializing /tmp/.mount_FreeCASqqWmW/usr/Mod/Tux... done
Log: Module: Part
Wrn: A3 available
Err: Program received signal SIGSEGV, Segmentation fault.
Err: #0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f8ad4e1bf20]
Err: #1 0x7f8a9feb0954 in PartDesignGui::ViewProviderDatumCoordinateSystem::updateData(App::Property const*) from /tmp/.mount_FreeCASqqWmW/usr/lib/PartDesignGui.so+0x24
Err: #2 0x7f8ad79ac530 in Gui::ViewProvider::update(App::Property const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x60
Err: #3 0x7f8ad79c1e36 in Gui::ViewProviderDocumentObject::update(App::Property const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x56
Err: #4 0x7f8ad761fd7e in Gui::Document::slotChangedObject(App::DocumentObject const&, App::Property const&) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x4e
Err: #5 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so(+0x19cd7e) [0x7f8ad6bb1d7e]
Err: #6 0x7f8ad6be4374 in App::DocumentObject::onChanged(App::Property const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so+0x124
Err: #7 0x7f8abee722b0 in Part::Feature::onChanged(App::Property const*) from /tmp/.mount_FreeCASqqWmW/usr/lib/Part.so+0x50
Err: #8 0x7f8ad6ce543b in App::Property::hasSetValue() from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so+0x3b
Err: #9 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so(+0x322164) [0x7f8ad6d37164]
Err: #10 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so(+0x199ddc) [0x7f8ad6baeddc]
Err: #11 0x7f8ad6bd4312 in App::Document::saveToFile(char const*) const from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so+0x312
Err: #12 0x7f8ad6bd4c58 in App::Document::save() from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so+0x298
Err: #13 0x7f8ad6c2ff23 in App::DocumentPy::save(_object*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so+0x43
Err: #14 0x7f8ad6c30194 in App::DocumentPy::staticCallback_save(_object*, _object*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADApp.so+0x24
Err: #15 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyCFunction_Call+0xf7) [0x7f8ad703cfa7]
Err: #16 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x250) [0x7f8ad6ff3240]
Err: #17 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4dde) [0x7f8ad7081dfe]
Err: #18 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2e2) [0x7f8ad6fef9e2]
Err: #19 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x44) [0x7f8ad6ff07c4]
Err: #20 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7f8ad70a626c]
Err: #21 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(+0x2176cf) [0x7f8ad70c26cf]
Err: #22 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(+0x252684) [0x7f8ad70fd684]
Err: #23 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyRun_StringFlags+0x7d) [0x7f8ad70fd71d]
Err: #24 0x7f8ad82e47aa in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADBase.so+0x6a
Err: #25 0x7f8ad7689018 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x98
Err: #26 0x7f8ad7689202 in Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x102
Err: #27 0x7f8ad75ffc79 in Gui::Document::save() from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x1f9
Err: #28 0x7f8ad796aeb1 in Gui::View3DInventor::onMsg(char const*, char const**) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x681
Err: #29 0x7f8ad75d206b in Gui::Application::sSendActiveView(_object*, _object*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x6b
Err: #30 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyCFunction_Call+0xf7) [0x7f8ad703cfa7]
Err: #31 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x250) [0x7f8ad6ff3240]
Err: #32 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4dde) [0x7f8ad7081dfe]
Err: #33 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2e2) [0x7f8ad6fef9e2]
Err: #34 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x44) [0x7f8ad6ff07c4]
Err: #35 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7f8ad70a626c]
Err: #36 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(+0x2176cf) [0x7f8ad70c26cf]
Err: #37 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(+0x252684) [0x7f8ad70fd684]
Err: #38 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libpython3.8.so.1.0(PyRun_StringFlags+0x7d) [0x7f8ad70fd71d]
Err: #39 0x7f8ad82e47aa in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADBase.so+0x6a
Err: #40 0x7f8ad7689018 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x98
Err: #41 0x7f8ad7689202 in Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x102
Err: #42 0x7f8ad7692126 in Gui::Command::invoke(int, Gui::Command::TriggerSource) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x316
Err: #43 0x7f8ad55217b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Core.so.5+0x780
Err: #44 0x7f8ad5d2f96e in QAction::triggered(bool) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0x32
Err: #45 0x7f8ad5d31239 in QAction::activate(QAction::ActionEvent) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0xcb
Err: #46 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5(+0x20e128) [0x7f8ad5dce128]
Err: #47 0x7f8ad5dce1e8 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0x88
Err: #48 0x7f8ad5e64ffa in QToolButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0xa
Err: #49 0x7f8ad5d5fc3e in QWidget::event(QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0xce
Err: #50 0x7f8ad5e65091 in QToolButton::event(QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0x4f
Err: #51 0x7f8ad5d3482a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0xde
Err: #52 0x7f8ad5d39095 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0x79d
Err: #53 0x7f8ad76579a9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x89
Err: #54 0x7f8ad550b186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Core.so.5+0x88
Err: #55 0x7f8ad5d3853f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0x283
Err: #56 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5(+0x1af554) [0x7f8ad5d6f554]
Err: #57 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03a6) [0x7f8ad5d703a6]
Err: #58 0x7f8ad5d3482a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0xde
Err: #59 0x7f8ad5d3a3f1 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Widgets.so.5+0x1af9
Err: #60 0x7f8ad76579a9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x89
Err: #61 0x7f8ad550b186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Core.so.5+0x88
Err: #62 0x7f8ad58b140b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Gui.so.5+0x6d3
Err: #63 0x7f8ad58b1ff7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Gui.so.5+0x175
Err: #64 0x7f8ad589edd4 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Gui.so.5+0x64
Err: #65 /tmp/.mount_FreeCASqqWmW/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5af0e) [0x7f8acfb55f0e]
Err: #66 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2cb) [0x7f8ad177f63b]
Err: #67 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/./libglib-2.0.so.0(+0x53881) [0x7f8ad177f881]
Err: #68 /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7f8ad177f90e]
Err: #69 0x7f8ad553a42b in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Core.so.5+0x63
Err: #70 0x7f8ad5507bc1 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Core.so.5+0x187
Err: #71 0x7f8ad550ba39 in QCoreApplication::exec() from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libQt5Core.so.5+0x105
Err: #72 0x7f8ad75cf55a in Gui::Application::runApplication() from /tmp/.mount_FreeCASqqWmW/usr/bin/../lib/libFreeCADGui.so+0x155a
Err: #73 /tmp/.mount_FreeCASqqWmW/usr/bin/freecad(+0x37cd) [0x56389d0067cd]
Err: #74 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f8ad4dfeb97]
Err: #75 /tmp/.mount_FreeCASqqWmW/usr/bin/freecad(+0x451f) [0x56389d00751f]
My configuration:
OS: Linux Mint 19.3 (MATE/mate)
Version: 0.19.21125 (Git) AppImage
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Italian/Italy (it_IT)
Assembly4 version: 0.9.4 2020-05-25
I hope this report will be helpful.
Thank you for your attention and sorry for my English .
