[Solved] [LinkStage3] FreeCad freezing problem
balrobs
Post by balrobs »
When I enable the shadow mode my Freecad freezes.
Steps:
1) Start FreeCad Link Branch
2) Create new document
3) Goto Part worbench
4) Create a cube solid
5) Zoom, rotate and pan view -> everything OK
6) Activate command View\Draw Style\Shadow (V,9)
7) Zoom, rotate and pan view -> Freecad freezes!
Can somebody replicate the problem?
OS: Windows 10 (10.0)
Version: 2020.11.09.22739 +2743 (Git)
Branch: LinkStage3
Hash: d34d2bd0674dfd55549f4a051c746564a850474b
Python version: 3.6.8
Qt version: 5.12.1
Re: [LinkStage3] FreeCad freezing problem
Does this happen with the official master as well? If not, please contact the author of the branch directly, probably in the assembly forum.
-alex-
Post by -alex- »
balrobs wrote: Wed Nov 11, 2020 10:13 am Can somebody replicate the problem?
JFYI here it works, no crash.
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Version: 0.19.25467 (Git)
Build type: Unknown
Branch: LinkStage3
Hash: 153b298a1cb52f5040fdc0ac371173586d2a2686
Python version: 3.7.3
Qt version: 5.11.3
Locale: French/France (fr_FR)
balrobs
Post by balrobs »
chrisb wrote: Wed Nov 11, 2020 4:48 pm Does this happen with the official master as well? If not, please contact the author of the branch directly, probably in the assembly forum.
No, it only happens with the LinkStage3 branch ... only this branch can render in shadow mode which causes the problem.
Thank you for guiding my post in the right direction. I will contact the author in the assembly forum.
Edit: I see this problem only in Windows, Ubuntu seems ok!
realthunder
Post by realthunder »
balrobs wrote: Wed Nov 11, 2020 6:37 pm No, it only happens with the LinkStage3 branch ... only this branch can render in shadow mode which causes the problem.
It is most likely related to your graphics card/driver. Let me guess, are you using some old AMD graphics card?
Try Assembly3 with my custom build of FreeCAD at here.
balrobs
Post by balrobs »
realthunder wrote: Thu Nov 12, 2020 9:37 am It is most likely related to your graphics card/driver. Let me guess, are you using some old AMD graphics card?
I'm using NVIDIA Quadro M2000.
BTW let me say that I appreciate so much your straordinary work. I'm using your branch mainly because of the toponaming problem and FreeCad realy NEEDS that feature.
Thank you, thank you and thank you again ;)
hrp
Post by hrp »
Hello All.
I'm a bit late but...
I've got exactly the same issue on two windows systems (8.1 and Server 2016)
After updating graphics drivers issue is resolved.
My card is similar - Quadro K2000D.
I hope this helps.
P.S Many thanks realtunther for your effort, bringing us your build.
Post by Kunda1 »
Can you reproduce on LinkDaily ?
balrobs
Post by balrobs »
hrp wrote: Tue Jan 25, 2022 7:46 pm I hope this helps.
Thnks @hrp for sharing this info :D
YES it helps. I can confirm that after a driver update now the freeze on my system with the lastes LinkDaily is solved!
OS: Windows 10 Version 2009
Version: 2022.111.30764 (Git)
Branch: LinkDaily
Hash: ef3092bcbca5475eff4eb7ff7933eb3e9bbbe4b9
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.6.0
