I'm sure I'm just having a brain cramp sort of day...
If you have two cylinders (think two batteries) and you want to constrain them side by side on a given axis.
What constraint is used in A2+?
A2+ assembly, cylinders, constrain side by side offset by cylinder diameter
Re: A2+ assembly, cylinders, constrain side by side offset by cylinder diameter
It isn't possible directly at moment. You need a helping sketch.
Possibilities:
1) Do a sketch with two circles directly in the assembly. Convert it to A2p. Constraint the cylinders by circularEdge constraints to the sketch
2) Have a mastersketch somewhere in another file. Import it and constraint the cylinders to that sketch.
I think i will add some missing constraints next time.
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Ok, thanks for the instruction.
Moved to Assembly.
Thanks @chrisb.
I put it here because it seems to me having a merged "Assembly" forum confuses me when the Assembly workbenches are different...
