Use a LCS created in a body in a part for assembly
run_the_race
Post by run_the_race »
I have a part called Foo_PART.
Inside Foo_PART is:
- Foo_BODY
- Foo_SPREADSHEET
Inside Foo_BODY is:
- Subshapebinder object
- Foo_LCS (local co-ordinate system) which depends on the shapebinder object
Now I have an assembly (Assembly4 WB) that I link Foo_PART into. To position Foo_PART I require Foo_LCS. However if:
  1. Foo_LCS is in Foo_BODY, then the assembly can't see the Foo_LCS.
  2. So then I move Foo_LCS out of Foo_BODY and into Foo_PART. Then it gets broken and is no longer linked to the Subshapebinder object.
  3. If I try make a new LCS for Foo_PART, then it is in the dettached state and does not work during assembly.
So how does one use a Foo_LCS in a body, in its containing part as well?
SIDE NOTE: If it helps I attached "touchscreen_7inch.FCStd" which has the "touchscreen_7inch PART" I am trying to use in an assembly. "pcb_mount_gpio1_bottom LCS" is the LCS I am trying to use for the assembly.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
(340.1 KiB) Downloaded 51 times
run_the_race
Re: Use a LCS created in a body in a part for assembly
Any workarounds to this problem?
run_the_race wrote: Wed May 05, 2021 10:14 pm Any workarounds to this problem?
Moved to Assembly forum.
Zolko
Post by Zolko »
run_the_race wrote: Tue May 04, 2021 10:25 am
yes, this is a recurring request, I have to implement it. This will be part of a next update, please stay tuned.
As a workaround, you can create an LCS in the Part, and attach it to elements in the Body. This will give you "Links go out of allowed scope " warnings that you can safely ignore IF you didn't change the Placement of the Body in the Part.
run_the_race
Zolko wrote: Thu May 06, 2021 12:37 pm
Ah okay I see, thank you for the context, I thought I was doing something wrong.
run_the_race
chrisb wrote: Wed May 05, 2021 11:03 pm
Thanks Chris!
Mark81
Post by Mark81 »
Zolko wrote: Thu May 06, 2021 12:37 pm yes, this is a recurring request, I have to implement it. This will be part of a next update, please stay tuned.
I faced the same issue with this version:
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.21.29501 (Git) Snap 134
Hash: 842fd4772bd2135168ebff0deccbfb1bd0639ae2
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Locale: Italian/Italy (it_IT)
Installed mods:
  * fasteners 0.3.45
  * 3D_Printing_Tools
  * CurvedShapes 1.0.3
  * Manipulator 1.4.5
  * Assembly4 0.12.0
  * fcgear 1.0.0
  * A2plus 0.4.56a
  * POV-Ray-Rendering
  * Render 2022.2.0
Would you please confirm if is still to be solved?
Zolko
Post by Zolko »
run_the_race wrote: Tue May 04, 2021 10:25 am So how does one use a Foo_LCS in a body, in its containing part as well?
Mark81 wrote: Wed Jul 13, 2022 7:38 am I faced the same issue with this version:
it sort-of is solved: in order to use in the top-level part an LCS (or any datum object) which is inside a child Body, you have to "import" it:
this will create another datum object of the same type in the top-level Part, and which is superimposed on the original datum object in the child Body. This acts as a sort-of ShapeBinder but applied to datum objects. Note that you can do this for Parts and Bodies nested many levels, not just for 1 Body. This is very handy when you import assemblies from STEP files.
Mark81
Post by Mark81 »
I've just tried but when I use this feature, the resulting imported LCS is not attached:
Screenshot from 2022-07-15 15-52-28.png (12.74 KiB) Viewed 1745 times
instead, dragging it from the Body to the top Part avoid this warning. Not sure about the consequences, but the Assembly4 seems to like it anyway.
I attach an example file.
actuator.FCStd
(26.31 KiB) Downloaded 23 times
Zolko
Post by Zolko »
Mark81 wrote: Fri Jul 15, 2022 1:54 pm I've just tried but when I use this feature, the resulting imported LCS is not attached:
No, the resulting LCS is not attached as per AttacherEngine. It is attached as per Asm4. Unfortunately, you get the un-fancy icon overlay pretending it's not attached. I might do a ViewProvider one day to correct this mis-representation
yes, it works if you don't do any strange things in between. You probably get the dreaded "Links go out of the allowed scope"
You can take my word: the correct behavior is as I described. If not, it's a bug and please report.
