Assembly3: How can I constraint a point to a line + curve?
crowalicious
Post by crowalicious »
I have the following scene where I need the bottom left vertex of the tile to follow the green line. How can I do this? Currently, the vertex only has a constraint to the vertical line and not the both the vertical line and the curve.
test_motion3.FCStd
(50.57 KiB) Downloaded 27 times
Re: Assembly3: How can I constraint a point to a line + curve?
Moved to Assembly forum.
