I need your help with Assembly 4.
I created the attached simplified Testcase.
I would like to place the two assemblies at the end of the Rods.
The Rods are Parts of the Assembly and I cannot create a LCS that refers to that Part.
However, I don't know how to create the LCS in PartBottom so that it can be aligned with the other instance, PartTop.
I am using FreeCAD_0.19-24276-Linux-Conda_glibc2.12-x86_64.AppImage with Assembly 4 AddOn.
Can you help ?
Many thanks
Christian
Assembly4 : LCS for Assembly of Assembly
- Testcase.tar.gz
- (45.11 KiB) Downloaded 61 times
Re: Assembly4 : LCS for Assembly of Assembly
Hi!
You can Import LCS from a part of a sub-assembly to the root of sub-assembly. After you can use imported LCS(s) in the main assembly//
- Testcase.zip
- (31.76 KiB) Downloaded 79 times
- Import LCSs.png (687.18 KiB) Viewed 6016 times
