See attached picture: I'm trying to find the rule that makes the green line coincide with the yellow dot. Is that possible?
The underlying part is fixed, the upper one is constricted in a way that the only possible movement left is sideways.
Thanks!
What rule should I use? (A2Plus WB)
- FreeCAD Poging1 1.jpg (221.12 KiB) Viewed 1672 times
Re: What rule should I use? (A2Plus WB)
Moved to Assembly forum.
for that the pointOnLine-Constraint is used ...
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
Thanks for the quick response.
Yes, I thought so, but as you can see in the attached picture, that option stays disabled after selecting the line and the point. Any ideas what the problem could be?
Solved: one needs to select the point first, then the line, and then the pointOnLine-constraint becomes active. Not the line first, then the point.
