Asm3 - assembly with ~200 fasteners.
bambuko
Re: Asm3 - assembly with ~200 fasteners.
Post by bambuko »
Svet wrote: Wed Jul 14, 2021 3:44 pm .....
OK, understand your reasons (even if I don't necessarily agree with them ;) )
BTW
re-using of bodies and components is easy using either way
broken elements are easy to fix or replace
I wasn't suggesting "just parts inside assy",
but... if it works for you, that's fine
Anyway... back to your 200 fasteners :)
Post by Kunda1 »
bambuko wrote: Tue Jul 13, 2021 4:23 pm The only thing that is different is that when I close the file I get this:
Just adding this for reference sake "Illegal storage access" https://github.com/realthunder/FreeCAD_ ... issues/701
@bambuko i realize you're already participating in that ticket ;)
Svet
Post by Svet »
Was able to put all needed fasteners with reasonable success.
I went route with fasteners inside nested assemblies to keep main assembly with minimum amount of constraints, and It works. Now I can move all axis by changing value of PointDistance constraints and assembly is stable enough.
Of course now I see "Illegal storage access" much often. For example, if I'll change screw size in Nema23 assy when any axis assy is opened then 99% FreeCAD will close with this error, but if I'll do the change and only after that will open parent assembly then it will work fine. So some limitation, but not deal breaker.
Full assembly.png (536.39 KiB) Viewed 893 times
Models in GitHub repository were updated. If someone want to take a look - clone repository, or download zip from:
https://github.com/Shkolik/CNC4060
Svet
Post by Svet »
Looks like in 0717 Daily build issue with 'Illegal storage' was solved! :)
