Collection of differences between original master version and realthunder
Report observations made with the new Toponaming branch.
thomas-neemann
Re: Differences between original master version and realthunder
Post by thomas-neemann »
K0DPW wrote: Thu Oct 14, 2021 5:55 pm
you could try to install a master version running on a stick and then copy the realthunder version over it, then everything could be there
K0DPW
Re: Collection of differences between original master version and realthunder
Post by K0DPW »
Thanks for your reply - I made a mistake in my initial post - the VCRUNTIME140_1.dll and VCRUNTIME140.dll file was available in the DLL folder within the BIN folder, but not in the BIN folder itself.
When I copied both files from the DLL folder, and pasted them directly into the BIN folder, now it worky OK.
Universal definition of truth applicable to ALL disciplines:
"Truth Does Not Contradict Itself"
thomas-neemann
this bar can be switched off in realthunder.
here a workaround for master
FreeCADGui.draftToolBar.Deactivated()
I found that here
https://forum.freecadweb.org/viewtopic. ... 20#p263706
edit
can you start freecad with this python command as an option?
thomas-neemann
test: loading a large fcstd file (204 mb) . master aborted after 20 minutes due to memory overflow.
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26306 (Git) AppImage
Branch: (HEAD detached at 6701788)
Hash: 670178869ecdca52f7dcd332c513cb0c82b25cce
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
realthunder approx. 5 min.
Version: 2021.1015.24301 +4280 (Git) AppImage
Branch: LinkDaily
Hash: 556c87868ea46796242156e9f73eae98259794b7
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
here is the test file (stp) that I saved as fcstd.
https://grabcad.com/library/isolation-g ... ing-line-1
https://www.youtube.com/watch?v=tiwl_suatd8
phpBB [video]
thomas-neemann
in the master and in realthunder the catch function lights up in the yellow circle, but it is not caught. an error message is thrown. a point on the object is probably necessary beforehand in order to get the result.
in realthunder, the defining geometry function generates the desired result with one click
https://www.youtube.com/watch?v=95tRqX7P3EQ
phpBB [video]
Version: 0.20.26554 (Git) AppImage
Branch: (HEAD detached at 817c14b)
Hash: 817c14b16af681b06aec7d8c79f744c7a88fa3c3
Qt version: 5.12.9
OCC version: 7.5.3
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
thomas-neemann
thomas-neemann
to create this part,
it makes sense to edit the sketch from both sides, also in connection with
in the realthunder version on maped sketches "map reversed" is available
edit
in master also possible
thomas-neemann wrote: Tue Jan 18, 2022 5:57 pm in master also possible
Since years!
thomas-neemann
chrisb wrote: Tue Jan 18, 2022 9:04 pm
Since years!
I had tried it before, but forgot. I noticed it with a video, I thought it would solve the problem with the mirrored sketches. it at least solves the problem with the empty sketch between two parts.
thomas-neemann
deleted because it was wrong
Last edited by thomas-neemann on Mon Jan 24, 2022 5:10 pm, edited 2 times in total.
