Revolve a selected sketch tool sometime make mistake in part design workbench.
Re: Revolve a selected sketch tool sometime make mistake in part design workbench.
maybe i found the key of this mistake.
groove tool maybe can not deal with removing(or delete) a place twice.
do these steps.
first , create a new body and create a new sketch in xy plane, draw a rectangle which has same position like my previous picture.
second, close the sketch and pad it with default height. and click 'ok'.
third, click the top face of cube to select, and click 'groove a selected sketch' tool.
next, in the preview window, click x axis to select. click 'ok', the cube itself will almost all cut by the top face.
it is wrong, because it should leave more.
in my picture, the right line of top face will remove the place in circle 1 and circle 3.
the left line of top face will remove the place in circle 2 and circle 3.
so the place in circle 2 and circle 3 was removed twice.
maybe this situation not well in program.
But at least groove tool is wrong in this case.
it gives me wrong result.
i don't know if it is the mistake of OCC.
do these steps.
- Snipaste_2021-08-30_20-33-21.png (50.41 KiB) Viewed 1991 times
- Snipaste_2021-08-30_20-47-32.png (75.05 KiB) Viewed 1991 times
- Snipaste_2021-08-30_21-01-39.png (57.71 KiB) Viewed 1991 times
another picture shows the theory.
- 2021-08-30_210438.png (87.73 KiB) Viewed 1979 times
we should talk with person of the company who program OCC.
check this mistake .
if it is the mistake of OCC, can we post the situation to proficient of OCC.
I'm not sure it's an OCC issue, because it has been tested on master and works correctly there.
i did a test in latest master version, it has problem more.
create a cube ,and select the top face. use revolve tool.
in the Revolve tool, i select x axis, it shows nothing.even after i click ok.
maybe the master version also have this problem.
need more test.
OS: Windows 10 (10.0)
Version: 0.20.25566 (Git)
Hash: 8c361dd3fc83840a911da950a845eb9f9342a0b6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: Chinese/China (zh_CN)
need more test.
Qt version: 5.12.9
OCC version: 7.5.2
Upload the file.
just create a cube, select the top face and click revolve tool.
the default axis is y axis, work well.
change the axis to x axis, then mistake shows.
- mistak2.gif (387.96 KiB) Viewed 1884 times
top face of cube revolve with y axis theory.
- Snipaste_2021-08-31_13-37-19.png (105.5 KiB) Viewed 1853 times
top face of cube revolve with x axis theory.
- Snipaste_2021-08-31_11-40-29.png (79.02 KiB) Viewed 1875 times
xais means axis .
i spell it wrong.
xais means axis .
i spell it wrong.
- Snipaste_2021-08-31_13-48-04.png (92.08 KiB) Viewed 1851 times
