Revolve a selected sketch tool sometime make mistake in part design workbench.
i use LinkStage3 .
i create first sketch and draw a line Parallel to y axis.
i create second sketch and draw a rectangle.
then i use Revolve a selected sketch tool to create a ring.
but sometime it work,sometime it makes mistake .
another case is i pad the sketch which draw a rectangle.
i select the top face to use Revolve a selected sketch tool,but it is wrong .
it sames nothing has changed.
i know sometime it is work, but it should be work all the time.
OS: Windows 10 Version 2009
Version: 2021.717.24301 +3627 (Git)
Branch: LinkStage3
Hash: f63a5ea7b459872a3798027df0ff25e776524859
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Chinese/China (zh_CN)
Branch: LinkStage3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- part design019.FCStd
- (24.78 KiB) Downloaded 61 times
- part design018.FCStd
- (43.27 KiB) Downloaded 50 times
- Snipaste_2021-08-29_17-11-04.png (85.17 KiB) Viewed 2219 times
Re: Revolve a selected sketch tool sometime make mistake in part design workbench.
I don't get what you're trying to say. Could you make a screencast of how it's working and how it's not working?
Regards / Viele Grüße
Max
Max
the work i made you can download and open it in linkstage3.
the result should be looks like this picture.you can Compare them.
- Snipaste_2021-08-29_16-28-03.png (48.04 KiB) Viewed 2198 times
i make two pictures in this dialog.
one is in Revolve a selected sketch tool, it look like good.
another is the picture after i click the ok in tool. it is not revolved. nothing has changed.
- Snipaste_2021-08-29_18-28-10.png (72.72 KiB) Viewed 2182 times
- Snipaste_2021-08-29_18-12-09.png (43.7 KiB) Viewed 2191 times
a gif shows the ring in tool and nothing happened after click 'ok'.
and sometime it worked very well.
- mistake.gif (777.71 KiB) Viewed 2179 times
first mistake i said. it is not a ring.
another gif.
another gif.
- mistake1.gif (573.71 KiB) Viewed 2160 times
- Shalmeneser
In yours 2 files, just opening and closing Sketch(000) do the job !!! ???
How to?
just click the sketch000, and close the sketch000 does not work in my computer.
maybe in you computer ,the program changed something.
- Shalmeneser
For me it's working.
OS: Windows 10 (10.0)
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: French/France (fr_FR)
you use master version, i am not.
i use linkstage3.
and sometime my version is work well with this tool, but sometime it is like my picture shows.
i use linkstage3.
