Assembly4 is not getting the Preferences Settings for Units
joeslide
Post by joeslide »
Units are set to English in Preferences. When placing parts in assembly4, units of translation are millimeters. Please advised. Version is 0.19 Revision 24291, Windows 10 2009.
Thanks,
Joseph
Re: Assembly4 is not getting the Preferences Settings for Units
Moved to Assembly forum.
Zolko
Post by Zolko »
joeslide wrote: Fri Sep 17, 2021 10:28 pm Units are set to English in Preferences. When placing parts in assembly4, units of translation are millimeters. Please advised
thank-you for the notice, we're awaiting your pull-request to correct this intolerable behavior
joeslide
Post by joeslide »
How do I submit a pull request?
Joseph
It is all open source, available on Github. You can create your own copy, modify it to your liking, and then make a so called pull request, which is isking for transferring your modeification to the publicly available master.
