Can't see the part in assembly 4
Routerworks
Post by Routerworks »
Attached is a drawing of a part. I am able to place LCSs on the part but when I link it into assembly 4 only the lcs coordinates show up, not the part. Tried toggling it, doesn't help.
Thanks for your help.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
HD2510 Screw Nut Holder.FCStd
(52.31 KiB) Downloaded 42 times
totalcad
Re: Can't see the part in assembly 4
Post by totalcad »
Your LCS(s) are belong to Body, but the solid object (suppose it was imported) doesn't. You need to drag&drop your object to Body:
1.FCStd
(70.36 KiB) Downloaded 45 times
totalcad
Post by totalcad »
...or you can create a "Part" (yellow icon) in Asm4 or in Part Design WB (Asm4 adds an initial LCS) and drop the solid to the Part, and after delete the Body (if you don't need to construct something else). I prefer to use the Part as a container for multiple objects (imported .STEP(s), Bodies etc.). This lets me to assign different colors to multiple objects, but the Asm4 defines the Part as one unit (which is useful for BOM in some cases). FC doesn't support multiple solids for Body at this moment(AFAIK)
1.FCStd
(14.5 KiB) Downloaded 45 times
Routerworks
Excellent explanation. Worked just fine.
Thanks for the help.
