What can cause that a pocket operation deletes the hole face of a body instead of just creating the pocket determined by an fully constrained sketch?
Thanks for your help!
Pocket deletes hole face
Re: Pocket deletes hole face
Hi and welcome to the forum!
There is a whole bunch of possible reasons, such as coplanar issues, fillet problems in previous steps. Upload your file and we may say more.
Thank you. I am uploading the project. The problematic body is in the "Case_front001 body" under Case_front part.
Steps to reproduce the problem. Make any sketch on XZ plane pad or pocket won`t work. I had to delete neary all other parts from the project, because it was bigger than the 1.46Mb upload limit.
Thank you in advance
- airq-sensor-case-v5-led-holder-testing-new.FCStd
- (759.84 KiB) Downloaded 23 times
- Shalmeneser
What is your version (look at the pink banner of the help forum) ?
- Shalmeneser
No constraints on first sketches ?
Problem with version ? (me 0.20 weekly)
20:04:32 <PropertyLinks> PropertyLinks.cpp(779): Lost link to airq_sensor_case_v5_led_holder_testing_new Import002 while loading, maybe an object was not loaded correctly
20:04:32 <PropertyLinks> PropertyLinks.cpp(779): Lost link to airq_sensor_case_v5_led_holder_testing_new Import003 while loading, maybe an object was not loaded correctly
20:04:32 <PropertyLinks> PropertyLinks.cpp(779): Lost link to airq_sensor_case_v5_led_holder_testing_new Import005 while loading, maybe an object was not loaded correctly
20:04:32 <PropertyLinks> PropertyLinks.cpp(779): Lost link to airq_sensor_case_v5_led_holder_testing_new Import006 while loading, maybe an object was not loaded correctly
20:04:32 <PropertyLinks> PropertyLinks.cpp(779): Lost link to airq_sensor_case_v5_led_holder_testing_new Import while loading, maybe an object was not loaded correctly
20:04:32 <PropertyLinks> PropertyLinks.cpp(779): Lost link to airq_sensor_case_v5_led_holder_testing_new Import021 while loading, maybe an object was not loaded correctly
20:04:32 Lost link to 'Import003' while loading, maybe an object was not loaded correctly
20:04:32 Lost link to 'Import002' while loading, maybe an object was not loaded correctly
20:04:32 Lost link to 'Import006' while loading, maybe an object was not loaded correctly
20:04:32 Lost link to 'Import021' while loading, maybe an object was not loaded correctly
20:04:32 SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
- Capture du 2021-10-19 20-03-30.png (42.2 KiB) Viewed 1791 times
I am using realthunder branch 2021.10.15 (Freecad 0.19.1). The first sketch is fully constrained.
- Shalmeneser
I can't do nothing to you.
I don't use Realthunder branch and your file doesn't open rightly on my computer.
You should always tell us your version.
You should have said that earlier to save considerable time from all the helpers who looked at your issue. Opening a realthunder model in master can produce arbitrary wrong or right results. Such issues can be reported on realthunder's github account or in the Assembly forum.
I move the topic there. It's all I can do.
