[ToDo]fix / pull request for polar pattern around datum line
tmoore
Postby tmoore » Fri Apr 18, 2014 8:48 am
Following the discussion in viewtopic.php?f=3&t=6307 I tried making a polar pattern around a datum line in the newly-updated assembly branch. It *almost* worked: during the polar pattern dialog the proper results are displayed, but confirming the dialog throws an error and the polar pattern feature cannot be created. It turns out that the wrong object was stored as the axis. https://github.com/timoore/FreeCAD_sf_m ... 616301553e fixes this bug; please pull and apply to jriegel/dev-assembly.
With this patch I can model the cylinder holes in my crankcase as a polar pattern rotated around the X-axis without creating any helper solid geometry, which I think is great!
Tim
jriegel
Site Admin
Re: fix / pull request for polar pattern around datum line
Postby jriegel » Tue Apr 22, 2014 7:50 am
Ok, I will take a Look
Stop whining - start coding!
bejant
Re: [ToDo]fix / pull request for polar pattern around datum
Postby bejant » Tue Apr 22, 2014 6:25 pm
Now cross-referenced to issue #1511.
