Does Assembly 3 support boolean operations? How about A2+ or Assembly 4?
exsolvespacer
Post by exsolvespacer »
I am designing a foam cutout for a flight case to store my drone in.
Hence I need a way to assembly parts of a drone and batteries and then "remove" this material from a virtual block of foam.
Is this possible with any of the assembly tools? I am looking in detail at Assembly 3 right now but can't see a way.
Thanks a lot.
M4x
Re: Does Assembly 3 support boolean operations? How about A2+ or Assembly 4?
Post by M4x »
You could export the assembly and use it as a cutting tool. I guess a shapebinder would work too. I can't test it myself at the moment.
exsolvespacer
M4x wrote: Mon Nov 15, 2021 6:09 pm You could export the assembly and use it as a cutting tool. I guess a shapebinder would work too. I can't test it myself at the moment.
Are you suggesting exporting as an STL then use that as a cutting tool? There are a lot of different export formats. Thanks.
M4x
Post by M4x »
No, if shapebinder isn't working, I'd look into using Part_SimpleCopy
bambuko
Post by bambuko »
What's wrong with using sub-shape binders and links?
(and yes - assembly 3)
If you get stuck - share a file/files
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
M4x
Post by M4x »
A, a link is a very good idea too.
exsolvespacer
M4x wrote: Mon Nov 15, 2021 7:35 pm A, a link is a very good idea too.
Okay, I am going to google "sub shape binders" and see what they are. BRB!
M4x
Post by M4x »
We've the wiki for such things ;) PartDesign_SubShapeBinder
exsolvespacer
M4x wrote: Mon Nov 15, 2021 10:14 pm We've the wiki for such things ;) PartDesign_SubShapeBinder
:-D
Zolko
Post by Zolko »
exsolvespacer wrote: Mon Nov 15, 2021 6:19 pm
if exporting, you should use STEP. Else, I'd use Part copy. In both cases, the result will be frozen, independent from the original form. If you want to keep association you should use SubShapeBinder, but I think it's more complicated.
