Assembly 4 Stopped linking parts
Routerworks
Post by Routerworks »
After quite a bit of assembly work "Assembly 4" It won't any longer allow me to attach another part. I keep getting the message as shown in the screen shot. Have no idea how to correct this if it is possible.
Thanks in advance for any help.
Routerworks
Assembly 4 screenshot
Screenshot 001.PNG (245.7 KiB) Viewed 3773 times
Shalmeneser
Re: Assembly 4 Stopped linking parts
Post by Shalmeneser »
Version ?
Error message in text mode for further research ?
Routerworks
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Routerworks
Sorry I didn't understand your second question.
Thank you.
Routerworks
Does this help. It is a copy of the error message.
'NoneType' object has no attribute 'TypeId'Running the Python command 'Asm4_insertLink' failed:
File "C:\Users\Laurence Salamey\AppData\Roaming\FreeCAD\Mod\Assembly4\insertLinkCmd.py", line 87, in Activated
if parent.TypeId == 'App::Part' and parent.getParentGeoFeatureGroup() is None:
Routerworks
Here is the warning:
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Screenshot 001.PNG (245.7 KiB) Viewed 3658 times
Zolko
Post by Zolko »
Routerworks wrote: Sat Nov 27, 2021 5:38 pm File "C:\Users\Laurence Salamey\AppData\Roaming\FreeCAD\Mod\Assembly4\insertLinkCmd.py", line 87, in Activated
in order to activate that part of the code, an existing link must be selected. In order to produce that error, that link must be outside of the assembly. Can you clear the selection (click somewhere in an empty space) and try again ?
Anyway, that is a bug that should not happen, I'll correct it
Zolko
Post by Zolko »
Routerworks wrote: Fri Nov 26, 2021 5:32 pm After quite a bit of assembly work "Assembly 4" It won't any longer allow me to attach another part. I keep getting the message as shown in the screen shot.
in your screenshot, the "Insert Link" command is inactive, which is very strange: can you please show the root of the model tree (the top-most part) ?
Routerworks
I tried clicking in open space and it didn't help.
When I click on an assembly body the Link lights up however, if I then click on "Link" I get the error.
Clicking on a part below won't light up the Link icon.
Thanks a lot for your help.
Screenshot 003.PNG (295.41 KiB) Viewed 3534 times
Screenshot 002.PNG (302.06 KiB) Viewed 3534 times
Routerworks
Screenshot 003.PNG (295.41 KiB) Viewed 3528 times
Screenshot 002.PNG (302.06 KiB) Viewed 3528 times
