performance issue in Pad command
Performance issue
You can see the results when I use the pad command up to face.
[Feature request]
In addition to this, there should be two options for up to face
The pad command should also have the option of thickness.By thickening a sketch that is not closed.
For example
https://www.youtube.com/watch?v=IseVwyGR2XY
[Feature request]
For example
- The result will be something like this.
- 6.jpg (26.03 KiB) Viewed 2162 times
- For example not closed sketch
- 5.jpg (24.96 KiB) Viewed 2162 times
- vid.zip
- up to two face result
- (880.01 KiB) Downloaded 22 times
- Second, its length has become infinite
- 4.jpg (114.39 KiB) Viewed 2172 times
- First of all, the direction of the pad has change.
- 3.jpg (143.04 KiB) Viewed 2172 times
Re: performance issue in Pad command
hamza wrote: ↑Sun Nov 28, 2021 7:07 am
OS: Windows 10 Version 2009
Version: 2021.1015.24301 +4280 (Git)
Branch: LinkDaily
Hash: 556c87868ea46796242156e9f73eae98259794b7
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Performance issue
You are using the link branch, which is discussed in the Assembly forum. I move your topic there. (If you would have used master, you should have posted to Help forum, not Open didscussion).
I have already made flags there. Didn't get any response so I thought let's try here. There is a quick answer here so I thought why not here
Let not do the helpers the work you could do yourself: Retry with the current master 0.20 and come back with the model if the behaviour is the same.
and everywhere else...
not very patient, are we
https://github.com/realthunder/FreeCAD_ ... issues/939
bambuko wrote: ↑Sun Nov 28, 2021 4:23 pmand everywhere else...
At least Link Daily does it, but 0.20 doesn't anything
hamza wrote: ↑Sun Nov 28, 2021 4:54 pmbambuko wrote: ↑Sun Nov 28, 2021 4:23 pmand everywhere else...
OS: Windows 10 (10.0)
Version: 0.20.26375 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
I tried it but you can see the result it doesn't work.
At least Link Daily does work. LinkDaily does not work well in Daily but it does
- 1.zip
- File
- (11.72 KiB) Downloaded 20 times
- 0.20 doesn't work
- 1.jpg (147.69 KiB) Viewed 1921 times
I may repeat myself, but in case it is unclear: If you want to discuss the branch, do it here. If you want to discuss 0.20, do it in the Help forum.
PartDesign works with solids inside of bodies. The extrude is neither of these. Make it a solid, import it as BaseFeature in the body and make a pad to first. That works perfectly: Please don't zip freecad files, they are already zipped. If you want better compression - which is appreciated for uploads to the forum -, set a higher compression level in the preferences.
- 1_cb.FCStd
- (43.25 KiB) Downloaded 21 times
chrisb wrote: ↑Sun Nov 28, 2021 5:33 pm I may repeat myself, but in case it is unclear: If you want to discuss the branch, do it here. If you want to discuss 0.20, do it in the Help forum.
If I have to ask for a new feature, where should I go?
It works by soldering
