Apparent TNP with RT FreeCAD (sample file attached)
exsolvespacer
Post by exsolvespacer »
I am using this branch:
Version: 2021.1015.24301 +3962 (Git) AppImage
Branch: LinkStage3
Hash: c6cb39697eb439caf7e5bd0208ca3082a7820547
And if I edit one of the angles in Sketch001 (e.g. change 45 to 44), and close it I get the dreaded TNP in Sketch004 which I thought was fixed in the RT branch. It appears to be because the external geometry goes "wrong" because the line it was based on was moved from 45 to 44 degrees.
Look at the green line in the bottom left of the screenshot above.
Does anyone know if this is my fault or FreeCAD's? Thanks.
Prop glue jig.FCStd
(134.35 KiB) Downloaded 40 times
drmacro
Re: Apparent TNP with RT FreeCAD (sample file attached)
Post by drmacro »
This is a perfect candidate for quadrant symmetry. 1/4 the work, 1/4 the constraints...
I'm not at a pc so can't look ATM.
Are you actually deleting any geometry in the sketch? Deletes are more likely than changes in dimensions to trigger tnp.
But, if the angle change causes an edge to go away or be added, possibly.
exsolvespacer
drmacro wrote: Wed Dec 08, 2021 9:39 pm This is a perfect candidate for quadrant symmetry. 1/4 the work, 1/4 the constraints...
No geometry is deleted. Simply a small angle change.
Do you mean quadrant symmetry using the TechDraw Workbench?
TheMarkster
Post by TheMarkster »
If I open the file I get lots of xy_plane for origin001 not found or some such. Since the Part container is superfluous I deleted it and kept the content.
Then I right click on the document and select mark for recompute, and recompute. Then Pad gives an error about a broken face. This is without modifying any angle values. Here is the sketch in question:
Snip macro screenshot-b5ec19.png (84.5 KiB) Viewed 2952 times
It is known that Pad facemaker cheese cannot manage such sketches with nested wires within nested wires.
Moved to Assembly forum. This branch is discussed here.
exsolvespacer
TheMarkster wrote: Wed Dec 08, 2021 10:19 pm If I open the file I get lots of xy_plane for origin001 not found or some such. Since the Part container is superfluous I deleted it and kept the content.
I don't get any errors like that... are you using the RT branch?
jpg87
Post by jpg87 »
exsolvespacer wrote: Wed Dec 08, 2021 9:32 pm ...
Although the Realthunder branch is very interesting, there are still times when problems arise when modifying.
So I allow myself to suggest some techniques to often avoid these problems :
- there are generally several ways to build an object, but I think it is always interesting to anticipate the choice of functions to use from a search for the geometric peculiarities of the object to be built ;
- try to simplify sketches;
- use relationships between dimensions when possible ;
- the "Extrude to face" function is very tempting, but extruding a length equal to a dimension that created the face is sometimes safer ;
- creating a reference (datum) plane linked to a face by a dimension used to create the face can be useful for attaching a sketch ...
- use rotational or translational copy functions when possible ;
- Realthunder's symmetry copy is very powerful !
My suggested solution is not perfect, but maybe it can give you some ideas ...
Prop glue jpg87.FCStd
(161.39 KiB) Downloaded 37 times
Prop glue.jpg (60.09 KiB) Viewed 2759 times
My website : http://help-freecad-jpg87.fr updated 2023/11/06
onekk
Post by onekk »
Many of these problem could be solved using scripting, where all is parametric, as you "hardcode" or ask user for input for parameters and do whatever you want.
Some very complex things are more easy this way, but it is not the "usual workflow".
You drive directly FreeCAD with most of his capabilities exposed, and with some advantage in calculations, as you have not to fiddle with preferences and finding GUI command in a menu or toolbar.
Drawback is that you have to code, so you have to write a code that is not an usual task for a "designer".
This way you left almost completely apart TNP as objects are ever the same despite their "names" as a python object has is "unique" reference, at least during program run.
Another advantage is that not matter how complex is the program, you have ever some thing to start even when version changing or other thing will modify something, maybe you have to change some invocation or change name of some methods, but the "relations" are in the program and remain written and readable even if the code will not produce useful design, all the relevant information are here and are not lost.
As said is a "completely different approach", so maybe it is not the "perfect solution" for every task and for every people.
Regards
Carlo D.
- Various other stuffs.
exsolvespacer
jpg87 wrote: Thu Dec 09, 2021 9:37 am
Thanks for all the tips. If I was designing from scratch, your method is how I would have approached it. It turned out as it is because originally it was not symmetric, but it turned out that way as I iterated the design.
exsolvespacer
onekk wrote: Thu Dec 09, 2021 3:11 pm Many of these problem could be solved using scripting, where all is parametric, as you "hardcode" or ask user for input for parameters and do whatever you want.
I understand OpenSCAD is like that.
The sooner the TNP is fixed the better. Sometimes I wonder how many hours of effort have been lost because of this.
