Problem with linear assemble of identical bodies
Vagulus
Post by Vagulus »
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
I am using Assembly 4.
Is there a problem with assembling a sequence of identical bodies along, say, the X-axis and mounting each successive body attached to the last? If I try more than two, bizarre things happen. The third body disappears from the 3D View and the first two swap places in the line. If I make a movie of it I could sell tickets. :lol:
"It is much harder to simplify than to complicate."
Joseph Kimble
Vagulus
Re: Problem with linear assemble of identical bodies
Post by Vagulus »
You think I jest! 8-)
Have a look at this: https://1drv.ms/v/s!ArMxdUYEh9fKwBc-MIs ... x?e=ciSQyZ.
There must be something wrong with something (probably something I am doing wrong). :oops:
Here is the Document https://1drv.ms/u/s!ArMxdUYEh9fKwBhmpWZ ... Q?e=JTG8Lw. It's only a baby but it's too big to upload. :( Perhaps instead of buying a ticket you could donate! ;) [wiki]https://wiki.freecadweb.org/Donate[/wiki]
Joseph Kimble
Zolko
Post by Zolko »
Vagulus wrote: Sat Jan 15, 2022 8:20 am Is there a problem with assembling a sequence of identical bodies along, say, the X-axis and mounting each successive body attached to the last?
No, it should work, but there was an unfortunate bug in version 0.11.5 : is that the one you're using ?
Vagulus
Post by Vagulus »
How can I find out which version I have?
Joseph Kimble
Zolko
Post by Zolko »
Vagulus wrote: Mon Jan 17, 2022 7:52 am How can I find out which version I have?
it says so during startup, and in the menu Help > Help for Assembly 4
Vagulus
Post by Vagulus »
I have Assemblt4 v. 0.10.7 ! :shock:
Joseph Kimble
Vagulus
Post by Vagulus »
Uninstall/Install.
Now v: 0.11.6
Same problem :(
Joseph Kimble
Zolko
Post by Zolko »
Vagulus wrote: Sun Jan 16, 2022 1:30 am Here is the Document https://1drv.ms/u/s!ArMxdUYEh9fKwBhmpWZ ... Q?e=JTG8Lw
this model doesn't correspond to the video you're showing. Also, the Body you're using has the AttacherExtension property set (MapMode) which introduces its own AttachmentOffset which interfers with Asm4's AttachmentOffset (this was the bug introduced in 0.11.5).
How did you get that property set ? The other Bodies in the file don't have it.
Vagulus
Post by Vagulus »
Zolko wrote: Mon Jan 17, 2022 9:20 am this model doesn't correspond to the video you're showing.
I ripped the insides out of that module to reduce the file size. Essentially it is the same beast.
Zolko wrote: Mon Jan 17, 2022 9:20 am How did you get that property set ? The other Bodies in the file don't have it.
Must be some key hit in error. :oops: It would seem more important to find out how I can UNSET that property. Is that possible?
Joseph Kimble
Zolko
Post by Zolko »
Vagulus wrote: Mon Jan 17, 2022 9:31 am It would seem more important to find out how I can UNSET that property. Is that possible?
you're right, I'll try to have a look at it.
