Assembly 4 (v0.12.0) – Animate Assembly does not start when run button is clicked ( v0.21.29321 (Git) AppImage )
OriginalContent
Post by OriginalContent »
[[ EDIT 6/29/22 : Added Assembly 4 version to subject title ]]
Greetings all,
This is my first forum post. Many thanks to every contributor that has made FreeCAD what it is today.
I’ve been reading the forum and learning FreeCAD for about 2 months. It's a wonderful tool.
I believe I found a bug in the weekly ( v0.21.29321 (Git) AppImage ) while practicing Zolko’s Assembly 4 tutorial #2:
Steps to reproduce the bug:
1. Open FreeCAD
2. File -> Open -> asm_tuto2.FCStd
3. Switch to Assembly 4 WB
4. Click Animate Assembly icon in assembly toolbar
5. Select the variable Angle_disk
6. Choose 40 and 400 as Begin and End values
7. Choose 1 as Step and 0 for Sleep
8. Click Run button
Expected result:
Assembly animates at least one iteration
Actual result:
No animation at all. When Animate Assembly Variable field is populated with Angle_disk, error messages show in Report view. ( See below )
Report View Error Messages:
Error logs from terminal ( ./FreeCAD.appimage -l ):
  File "/home/bob/.local/share/FreeCAD/Mod/Assembly4/./AnimationLib.py", line 387, in sliderMoved
    self.setVarValue(varName, varValue)
  File "/home/bob/.local/share/FreeCAD/Mod/Assembly4/./AnimationLib.py", line 350, in setVarValue
    self.rootAssembly.recompute('True')
TypeError: argument 1 must be bool, not str
I was able to successfully animate the assembly in the latest official release ( v0.20.29177 (Git) AppImage ). And that is why I believe it's a bug.
If this turns out to be a bug, should I submit a bug report?
Cheers,
OS: Ubuntu 20.04.4 LTS (XFCE/xubuntu)
Version: 0.21.29321 (Git) AppImage
Hash: 8ee773362e08d703bce9cfdcefd8e4ad424a7d44
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Assembly4 0.12.0
  * DynamicData 2.46.0
  * dodo (Disabled)
asm_tuto2.FCStd
(58.32 KiB) Downloaded 34 times
Last edited by OriginalContent on Wed Jun 29, 2022 5:11 pm, edited 4 times in total.
Re: Assembly 4 – Animate Assembly does not start when run button is clicked ( v0.21.29321 (Git) AppImage )
Moved to Assemly forum.
Zolko
Post by Zolko »
OriginalContent wrote: Tue Jun 28, 2022 7:18 pm
good catch, yes, this is definitively a bug. FreeCAD v0.20 probably ignored that keyword and that's why it hadn't been triggered before. I think I fixed it in the new Asm4 v0.12.1 version. Can you please update the workbench and test again ? (should work in FreeCAD v0.19, 0.20 and 0.21)
OriginalContent
Zolko wrote: Wed Jun 29, 2022 6:49 am Can you please update the workbench and test again ? (should work in FreeCAD v0.19, 0.20 and 0.21)
I updated the Assembly 4 addon to the latest version, v0.12.1, and tested assembly, asm_tuto2.FCStd, on the following FreeCAD versions:
v0.19.24366 (Git) AppImage ( aka 0.19.3-Linux-Conda_glibc2.12-x86_64.AppImage )
v0.20.29177 (Git) AppImage ( latest official release )
v0.21.29321 (Git) AppImage ( latest weekly release )
I was able to successfully animate the assembly manually and with the Animate Assembly function in each version with no errors.
Thank you for your prompt reply and the excellent work you've done to create Assembly 4!
Cheers,
JustEnoughDucks
Re: Assembly 4 (v0.12.0) – Animate Assembly does not start when run button is clicked ( v0.21.29321 (Git) AppImage )
Post by JustEnoughDucks »
Hello, I am at v0.21.30121(git) AppImage with Assembly4 v0.12.3 installed.
I am having the same problem where I cannot solve nor animate the assembly due to the same error:
00:12:51  Running the Python command 'Asm4_updateAssembly' failed:
  File "/home/lagomankor/.local/share/FreeCAD/Mod/Assembly4/updateAssemblyCmd.py", line 43, in Activated
    obj.recompute(True)
I would think if it was fixed then this shouldn't be an issue anymore. Must be something different going wrong?
Zolko
Post by Zolko »
JustEnoughDucks wrote: Wed Aug 31, 2022 10:24 pm I am having the same problem where I cannot solve nor animate the assembly due to the same error:
not enough information
