Body Duplication in Assembly 4
Vagulus
Post by Vagulus »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/New Zealand (en_NZ)
Installed mods:
  * Assembly4 0.12.2
  * BOLTSFC
  * Curves 0.5.1
  * dodo
  * fasteners 0.3.46
  * parts_library
AP-04-018 is the Idler Shaft. I have added one only AP-04-019 Idler Flange. I got two for the price of one. :o
220814 - Drive Assy.png (12.07 KiB) Viewed 1120 times
I am not delighted. I really only want the one and it should be the one on the right. Something else goes on the left end of the shaft.
How do I get rid on the left-hand one so I can concentrate on rotating the right-hand one so the keyway lines up properly?
Thanks
Drive Parts Assy.FCStd
(270.75 KiB) Downloaded 37 times
"It is much harder to simplify than to complicate."
Joseph Kimble
ppemawm
Re: Body Duplication in Assembly 4
Post by ppemawm »
Vagulus wrote: Sun Aug 14, 2022 6:30 am I got two for the price of one.
You have the original visible in the Parts folder. Hide that.
Locate the link on the proper end of the shaft with the appropriate LCS or attachment offset.
"It is a poor workman who blames his tools..." ;)
Vagulus
Post by Vagulus »
Thank you
Joseph Kimble
Shalmeneser
Post by Shalmeneser »
You should use more often PartDesign_Revolution and perhaps PartDesign_WizardShaft
AP-04-018 is nearly symmetric ?
Vagulus
Post by Vagulus »
Shalmeneser wrote: Wed Aug 17, 2022 8:14 pm You should use more often PartDesign_Revolution and perhaps PartDesign_WizardShaft
Using PartDesign Revolution for a simple shaft seems a bit fiddly to me - all those dimensions to define. Perhaps its because of a trade background rather than a design background that I prefer to take a lump of material and cut bits off it. :lol:
Shalmeneser wrote: Wed Aug 17, 2022 8:14 pm AP-04-018 is nearly symmetric ?
Nearly, but not quite. Done that way because it is attached on the basis of the YZ plane.
I appreciate your tutorial instincts. Thanks. Your comments are always studied and valued.
Joseph Kimble
