+1 - this is great!!
[Quick Measure is now an Addon] Is anyone willing to try another measuring program?
Re: [Quick Measure is now an Addon] Is anyone willing to try another measuring program?
I'm glad users are finding this useful.
I noticed that users cannot measure from FreeCAD's Origin, nor can we measure from the middle of a straight edge, so I added two features.
1: A button that inserts a vertex at the Origin, press the button again and the vertex is removed.
2: Select a straight edge, press "Mid Line" and a vertex is added to the mid-point if an edge. Multiple vertexes can be added, pressing the "Del Mid Lines" button will remove them all.
You can use these vertexes for your measurements.
Dan
@dan-miel - I don't know whether this a display issue in my system or a bug? It has only just started occurring
FreeCAD Version latest weekly build appimage.
[/code]
[code]
System: Kernel: 5.14.0-3mx-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14.0-3mx-amd64
root=UUID=<filter> ro splash quiet
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm 4.14.0 vt: 7
dm: LightDM 1.26.0 Distro: MX-19.4_ahs_x64 patito feo March 31 2021
base: Debian GNU/Linux 10 (buster)
Machine: Type: Laptop System: LENOVO product: 20NFA00PAU v: ThinkPad E595 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NFA00PAU serial: <filter> UEFI: LENOVO v: R11ET40W (1.20 )
date: 11/17/2020
Battery: ID-1: BAT0 charge: 40.4 Wh (98.5%) condition: 41.0/45.7 Wh (89.7%) volts: 12.2
min: 11.1 model: Celxpert 5B10W138 type: Li-poly serial: <filter> status: Unknown
cycles: 16
CPU: Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108102 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36731
Speed: 2278 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz): 1: 2278
2: 2232 3: 1820 4: 1762 5: 1654 6: 1562 7: 1660 8: 1555
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics: Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Lenovo ThinkPad E595 driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks type: USB driver: uvcvideo bus-ID: 3-2:3 chip-ID: 13d3:5415
class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: xfwm4 v: 4.14.0 driver: loaded: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 30 size: 1600x900mm (63.0x35.4")
diag: 1836mm (72.3")
OpenGL:
renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.42.0 5.14.0-3mx-amd64 LLVM 11.0.1)
v: 4.6 Mesa 20.3.5 direct render: Yes
- QM Display1.png (29.98 KiB) Viewed 809 times
I'm not sure what is it is. I just downloaded the latest FreeCAD but my system seems fine.Laurie Hartley wrote: ↑Mon Nov 07, 2022 1:17 am I don't know whether this a display issue in my system or a bug? It has only just started occurring
Is anyone else having problems?
OS: Windows 10 Version 2009
Version: 0.21.30858 (Git)
Hash: 7a5019b2625a148acb23fb915df48ffa69636fe9
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
* A2plus 0.4.60b
* Assembly4 0.12.4
* BIM 2021.12.0
* Curves 0.5.11
* fasteners 0.4.16
* Manipulator 1.4.9
* QuickMeasure 2022.10.28
- Screen.JPG (31.35 KiB) Viewed 783 times
@dan-miel
I have had another look at this - the problem only appears if the style sheet is changed - could you try darker blue and light green on your system maybe.
