Cannot pad from datum plane attached tangent to curved pad
exsolvespacer
Post by exsolvespacer »
In this file, Pad003 only appears when the pad is greater than 5mm. I would like it to be 1.75mm. What am I doing wrong? Thanks.
file.FCStd
(715.99 KiB) Downloaded 41 times
Version: 2022.1021.26244 +5249 (Git) AppImage
Branch: LinkDaily
Hash: d307b5c936403e8dca3f24b5c1e64bd16c88b28d
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Re: Cannot pad from datum plane attached tangent to curved pad
Origin of the Part seems to be broken, perhaps because I don't use Link branch; I have deleted the whole container - without its conents, of course.
The pad works with 1.75mm in master:
BTW: "file" is not the best of all filenames.
OS: macOS 10.16
Version: 0.21.31035 (Git)
Hash: c8074a972ee233d303e50e5d525aecae09c1cd04
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * DynamicData 2.46.0
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.6.1
file_cb.FCStd
(500.64 KiB) Downloaded 37 times
exsolvespacer
Okay, I'll see what RT says about this as it looks like a bug. Thanks for checking it in master.
exsolvespacer
RT says it is a "common OCC tolerance problem" and suggested doing a pad followed by a pocket. This solved the problem.
