Dangerous curves
Discussions about the wiki documentation of FreeCAD and its translation.
Re: Dangerous curves
Postby chrisb » Wed Sep 15, 2021 5:13 am
esr wrote: Wed Sep 15, 2021 2:49 am Another dangerous curve: pockets that pocket empty space, because you have to reverse them, because FreeCAD isn't smart enough to default to pocketing into the surface the sketch is placed on rather than going "positive" with respect to global coordinates.
FreeCAD is indeed smart enough to handle pockets correctly, whos Sketches are attached to faces. However, due to other reasons this is not recommended.
esr
Postby esr » Sat Sep 18, 2021 2:14 pm
chrisb wrote: Wed Sep 15, 2021 5:13 am
Maybe it is now - I'm running the repository head version and will test. I definitelty saw it being stupid this way in 0.18.4, I had to ask about it and was told about the "Reverse" checkbox, which indeed fixed the problem.
Roy_043
Postby Roy_043 » Sat Sep 18, 2021 3:26 pm
esr wrote: Sat Sep 18, 2021 2:14 pm I definitelty saw it being stupid this way in 0.18.4
Please avoid terms such as 'stupid'. They unnecessarily charge the discussion. Everybody makes mistakes, but the word 'stupid' seldom applies.
Postby chrisb » Sat Sep 18, 2021 3:32 pm
esr wrote: Sat Sep 18, 2021 2:14 pm I definitelty saw it being stupid this way in 0.18.4, I had to ask about it and was told about the "Reverse" checkbox, which indeed fixed the problem.
I would like to see that example. Pockets of sketches attached to faces worked in 0.18 definitely the same sensible way as they do now: they go into the face (or rather into the material behind the face). Did you receive that recommendation here in the forum?
