[In progress] About modules and workbenches in wiki.
Discussions about the wiki documentation of FreeCAD and its translation.
heda
Re: [In progress] About modules and workbenches in wiki.
Post by heda »
as far as I understand he has:
- deleted the workbench page (the one with redirect to module)
- moved the page to be "x_Workbench"
- new "x_Module" pages with redirect to workbench
- for all langs
there is a description of the process earlier in this thread authored by Roy_43.
yes, it is unclear why it fails, he has tried several times - there has to be a log somewhere that has some hints of why it has failed earlier on part, all the others have worked on the first go afaik.
Roy_043
Post by Roy_043 »
Kunda1 wrote: Sat Sep 11, 2021 3:27 pm @Roy_043 so Part Workbench pages already exist. So I'm just adding a redirect from Part Module and all their translation pages? i.e erasing the contents of the page and adding:
#REDIRECT [[Part Workbench]]
Correct?
No! See heda's answer.
Kunda1 wrote: Sat Sep 11, 2021 3:27 pm Are you trying to figure out why you aren't successfully able to rename Part_Module?
Yes!
Evgeniy
Post by Evgeniy »
All complited?
Roy_043
Post by Roy_043 »
There are three remaining issues:
  1. The Plot_Module page has not been renamed. AFAIK Heda has contacted the developer to check if it is OK to rename the page. We are waiting for an answer.
  2. The Part_Module page cannot be renamed for some reason. After several failed attempts we are now waiting for more information.
  3. Some work has been done on the sidebar. But this is not yet finished.
Evgeniy
Post by Evgeniy »
Ok
Roy_043
Post by Roy_043 »
Update: The Plot_Module page has been renamed.
