Hello.
I noticed you are running a 32-bit windows.
Since FCGear needs numpy to run and there is a known problem
with numpy on 32-bit System i would suggest that you replace your
local numpy version as described here and try again.
Roland
FCGear
Re: FCGear
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Re: FCGear
Since the problem is recurring, I added a note to How to install additional workbenches
Other places where add this?
Renato
Renato
Re: FCGear
Maybe the release notes ?renatorivo wrote:Other places where add this?
Maybe the FreeCAD files page ?
BTW, did you read this post ?
This affects Linux 0.16.6703 ...
Roland
Re: FCGear
I tried to import the angle from a spreadsheet. The import is correct.r-frank wrote:BTW, did you read this post ?
Do you know how to replicate the problem quickly, without following the tutorial.
Renato
Re: FCGear
Verified with FreeCAD 0.16.6703 on Linux Mint 17
> Start FreeCAD
> switch to Sketcher Workbench
> create sketch on X/Y-plane
> draw first line from Origin to somewhere upper right corner
> constrain line with angle in respect to X-axis, lets say at 40°
> assign name to constraint, lets call it "angle"
> draw second line from origin to upper right corner
> use angle constraint from line to X-axis on the second line
> click on blue symbol to assign expression
> type "Sketch.Constraints.angle" and a small number will be displayed as result (that is 40 degrees in radians > wrong result ...)
Result should be 40°, but is 0.69...
> Start FreeCAD
Re: FCGear
Thank you. I confirm.
With FreeCAD 0.16.6703 on Ubuntu 16.04.01 64-bit
Re: FCGear
It's now fixed in the latest update 0.16.6707.
viewtopic.php?f=3&t=18764
OS: Ubuntu 14.04.5 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Build type: None
Qt version: 4.8.6
Re: FCGear
For the 0.16.6706 x86 installer I swapped out the numpy so the user shouldn't have to. As I don't have problems on my system with either numpy I can't test. The problem exists for older versions and I haven't yet updated the Libpack.r-frank wrote:I noticed you are running a 32-bit windows.
"fight the good fight"
Re: FCGear
Many thanks re installation help.
I installed seamlessly on a 64 bit computer at work, and today updated numby and successfully installed on my 32 bit home computer.
Lee
Lee
