PartDesign Next in wiki
NormandC
Re: PartDesign Next in wiki
Post by NormandC »
renatorivo wrote: Tue Mar 13, 2018 5:49 pm I did a little research. It seems that "a translation administrator marks the page for translation." See https://www.mediawiki.org/wiki/Help:Ext ... nistration
Then I think you have to ask to switch from editor to editor and admin (extended rights for translation management)
I already mentioned this many times already!
Last time I did just here 3 days before.
NormandC wrote: Sat Mar 10, 2018 3:53 pm To see the "marked for translation" link, you need to be a wiki admin, which you aren't. Do you want the extra responsibility? ;)
ulrich1a
Post by ulrich1a »
Is there really a need for a page: https://www.freecadweb.org/wiki/index.p ... _NewSketch? There exists already https://www.freecadweb.org/wiki/Sketcher_NewSketch
Both have nearly the same content. The dialogs from the different workbenches differ somewhat, but this can easier be handled in one page. It it less work for translators.
I know, that then the tip-help does actually not work. But this should then be changed in the source code.
Any opinions?
Ulrich
ulrich1a wrote: Sat Mar 24, 2018 3:12 pm Any opinions?
I would like to see it on one page, however it might not be easy to get it clear:
- When called from PDN a body is created and set active if none exists
- There are more parameters to be set (which I never understood and never investigated further)
- The selection of the attachment plane takes place in 3D view
The last point could be adapted in the source code as well, but sure not before 0.18.
