Help for first steps within the wiki
Discussions about the wiki documentation of FreeCAD and its translation.
catman
Re: Help for first steps within the wiki
Postby catman » Sun Mar 10, 2019 2:25 pm
cds4byu wrote:
Sun Feb 25, 2018 10:38 am
There is one command in the source that I don't understand:
<!--T:8-->
Is this syntax explained anywhere? I've searched the wiki and the forums, and I can't see it explained.
I have now found that this is translation infrastructure that is automatically added. I should not modify these when I am updating the page. For more information, see https://www.mediawiki.org/wiki/Help:Ext ... on_example
I had the same problem, but I was not aware other have it as well. I think that information should go to the wiki. The best place I figured was the
WikiPages:Before Starting
I added a section on what I understood. Please review the text (https://www.freecadweb.org/wiki/WikiPag ... e_Starting) and tell me what is wrong, so I can correct it.
I find the page title unfortunate, because "WikiPages" does not tell what the page is about, it too general. Better would be "Editing Guidlines" or ""Wiki Editing". However, since the page is hard to find anyway I would suggest to put a link with that name to that page into the sidebar just below "Tutorials". I believe one needs admin rights to do that.
gianfrancodp
Postby gianfrancodp » Tue Mar 24, 2020 6:16 am
I'm wanting to fix some errors in this page:
https://wiki.freecadweb.org/Import/Expo ... cOpenShell
For example at step 4 the correct command is
import sys
print (sys.paht)
I'm a new user, I can suggest to someone else these editing?
Thank you.
PrzemoF
Postby PrzemoF » Tue Mar 24, 2020 11:17 am
import sys
print (sys.paht)
Thank you.
Welcome to the forum! Take a look here: https://forum.freecadweb.org/viewtopic.php?f=21&t=6830
Baritone
Postby Baritone » Sun May 17, 2020 8:57 am
NormandC wrote:
Wed Oct 17, 2018 4:52 am
qurn wrote:
Tue Oct 16, 2018 1:08 pm
Inconsistency:
- The section Usage is sometimes named "Usage", "Use" or "How to use". The "Template" https://www.freecadweb.org/wiki/Draft_Line says How to use.
I agree it should be "How to use". Unfortunately this change on a massive scale would invalidate a lot of translations on translated pages that have nonetheless a consistent naming scheme in their language. When I happen upon such pages I do change "Usage" or "Use" for "How to use", but I also immediately confirm the corresponding translations afterwards. This is very tedious, and requires admin rights.
I am a translator. Please, do not change "Usage" or "Use" for "How to use". "Usage" is becoming a new standard in fact on all updated pages. Let everything remain as it is.
hmk
"Usage", not "How to use"
Postby hmk » Fri Jan 15, 2021 11:57 am
Inconsistency:
Since this thread is pinned, just wanted to point out that the current consensus seems to be Usage! The above mentioned Draft Line was changed accordingly: https://wiki.freecadweb.org/index.php?t ... did=587361
