wandererfan wrote: ↑Mon Mar 05, 2018 11:28 pm
Is this an old one? It talks about Sourceforge accounts and doesn't have Path or TechDraw.
The helpfile is generated from the wiki-pages and includes what is in the wiki-pages. I have installed the published help file and it has TechDraw and Path.
Installing a new help file to an existing FreeCAD requires to open the help and deinstalling first the old help-file. The required dialog is in the help-assistant edit/preferences:
After removing close the preference dialog and open it again. Now add the new helpfile.
Got it working. My steps:
- remove "org.freecad.usermanual" in Help>Help>QtAssistant>Edit>Preferences>Documentation
- shutdown FC
- move new *.qch, *.qhc to buildDir/doc
- restart FC
- add the *.qch file in Help>Help>QtAssistant>Edit>Preferences>Documentation
Note that WhatsThis support in FreeCAD was inherently broken. Wrong command names set compared to what was on the Wiki, things like Python based commands where using tooltip information instead (code needed to change) ... A lot of this got resolved in FreeCAD 0.17 development cycle. FreeCAD 0.17 will therefore be the first release having a decent level of WhatsThis support. I wouldn't worry about it too much if it will not be at 100%. It will still be much better then it ever was.
If there is any interest (due to the WhatsThis revolution as seen in FreeCAD 0.17 development cycle) i can invest a bit of effort and make a small and simple GUI tool. Where inspecting WhatsThis information for FreeCAD commands should i guess be a bit easier.
NormandC wrote: ↑Wed Mar 07, 2018 1:54 am
I commented the PR. I believe git commit 898cafd7 can be merged without affecting translations.
The reason may be that it could be difficult to merge the all the ts-file now at crowdin, if an additional translation string will be added. Then the ts-files at crowdin and those in the sources have different numbers of strings to be translated.
I would ask to split the PR into one that has only the changes regarding the
