Basic Part Design Tutorial
- wandererfan
The attached file was created in 0.17 by following @Quick61's tutorial: Basic_Part_Design_Tutorial.
I don't know if it is a good intro to 0.17 PD or not.
If it seems reasonable, I can edit Mark's work into an equivalent page for 0.17.
- bpdt.fcstd
- (58.5 KiB) Downloaded 49 times
Re: Basic Part Design Tutorial
I think it is.
But please forgive me for my being blunt, there are a few problems with your model.
- DatumPlane and DatumPlane001 are identical.
- Sketch001 is empty.
- DatumPlane and DatumPlane001 are both mapped to the rear face of Pad. What's their purpose? Sketch002 could have been mapped directly to Pad's rear face instead.
- The same question could be asked for DatumPlane002, what advantage does it bring over mapping Sketch004 directly on the sloped face of Mirror001?
- Transformation features could only be based on a single feature up to v0.16, and they could only be based on the last feature in the tree. But in v0.17, more than one feature can be selected (although awkwardly). So a more efficient practice in v0.17 is to create Pocket, then Pad001, and then apply a single Mirrored from those two features.
To see how jrheinlaender (who first developed the new stuff in PartDesign "Next") envisioned use of datum planes, you can have a look at this tutorial which is still in my list of pages to update. PartDesign Bearingholder Tutorial I (IIRC I had rewritten it up to the Machining step in a separate Sandbox page, images needed to be redone)
I initially thought his tutorial could simply be updated, but now I'm not so sure. Things are much different so maybe it does deserve a separate page.wandererfan wrote: ↑Sun Apr 01, 2018 6:35 pm I can edit Mark's work into an equivalent page for 0.17.
- wandererfan
Hey, don't sell yourself short
Your model is a good start, no need to start from scratch.
It would also be fun to add a follow-up tutorial: using the same model, create a drawing page in TechDraw, and use it in place of the actual drawing page made in the Drawing wb.
- HarryGeier
What about that one ?
featuring:
3 Body´s
shapebinder
datum geometry points lines and planes
pad from surface
transformed body
i would recreate it in a video , describing it piece by piece or even a tex with the descriprion how it was done
it has one drawback .. if i transform the ring , it does not move along the hex bolt.. as i did not find a way yet, to align a body´s origin axes along a plane or something else i could take from the hex-bolt .. at least not in the Standard FreeCAD and we should avoid to use any 3rd Party macros or wb´s at that stage to provide remakebility with the fresh installation
Any ideas are welcome...
featuring:
3 Body´s
shapebinder
pad from surface
transformed body
- demoblock.FCStd
- (139.18 KiB) Downloaded 49 times
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
- wandererfan
"Intermediate Part Design Tutorial"?HarryGeier wrote: ↑Mon Apr 02, 2018 6:23 am What about that one ?
featuring:
3 Body´s
shapebinder
pad from surface
transformed body
- HarryGeier
Why intermediate ?
- wandererfan
To me, a brand new user is going to be overwhelmed by:
3 Body´s
shapebinder
pad from surface
transformed body
That seems more like the curriculum for experienced 016 users looking to transition to 017 - so an intermediate user.
- HarryGeier
I agree,
basically then we should re-create them without these features , just in the proper way for .17 leaving off the "old" .16 specific things.
I) remember when i once did the Demo in .14 , i was close to give it all up, as it did not really understand how it should work.. even though i came from Solidworks and MasterCam .
If you like i will create a set of basic .17 PD demos, step by step. I have most of of them at hand already from my public highschool courses.
- HarryGeier
Here is my version of the "good old" tutorial , just replaced the helper pad with a datum plane, fixed 90 degrees to the vertical centered edge of the first sketch ( right 26mm side ) . Probably it would even be better to fix it to the origins and offset it until it goes beyond the "back face" and then pocket thru it.
i also attached a few screenshots that should then be replaced, new sketch orientation, add body, add sketch etc..
- 2018-04-03 09_49_22-NotificationsForm.png (23.85 KiB) Viewed 1499 times
- 2018-04-03 09_50_02-NotificationsForm.png (24.31 KiB) Viewed 1499 times
- 2018-04-03 09_50_22-NotificationsForm.png (24.37 KiB) Viewed 1499 times
- 2018-04-03 09_50_50-NotificationsForm.png (39.21 KiB) Viewed 1499 times
- tut1.FCStd
- (47.92 KiB) Downloaded 42 times
