There's been a couple of comments in the forum about the non-existence of this: Basic TechDraw Tutorial. Any comments or suggestions would be welcome.
One specific problem - I could not get the language bar to appear. I put it at the top, the bottom and in between, but it refuses to show up.
Thanks,
wf
Basic TechDraw Tutorial for Review
- wandererfan
Re: Basic TechDraw Tutorial for Review
Thankswandererfan wrote: ↑Thu Aug 02, 2018 5:44 pm There's been a couple of comments in the forum about the non-existence of this: Basic TechDraw Tutorial. Any comments or suggestions would be welcome.
Now there is.wandererfan wrote: ↑Thu Aug 02, 2018 5:44 pm One specific problem - I could not get the language bar to appear. I put it at the top, the bottom and in between, but it refuses to show up.
Great! It looks pretty complete, why not rename it to Basic TechDraw Tutorial now?
I made minor edits to the Titlebox. You don't need to show the Author name's twice, with and without link. You are linking to a non-existing User wiki page: you can create one, or remove the link, or link to your forum profile instead.
I added a carriage return <br /> between the two linked files, I thought it would be clearer for the 2nd file to be on a line below? You can delete it if you don't like. BTW the second file brings up a Jedi who tries to play mind tricks on me.
One other thing: in "Going further", you show an image of an iso view with dimensions. But the dims' extension lines can only be projected correctly in v0.18.
This is how it will look in v0.17:
Maybe we should add a comment to the effect proper isometric dim extension lines are only implemented in v0.18, otherwise there's going to be a lot of questions.
It appears only after a wiki admin such as Renato or myself (and a few others) marks a page for translation. Each time there is a new revision to a page, an admin needs to mark the page for translation again. Let me know if you want me to bump you up to wiki admin status. I won't begrudge you if you don't.wandererfan wrote: ↑Thu Aug 02, 2018 5:44 pm One specific problem - I could not get the language bar to appear. I put it at the top, the bottom and in between, but it refuses to show up.
- wandererfan
Because I'm not an administrator and can't "manage translatable pages"!NormandC wrote: ↑Thu Aug 02, 2018 10:03 pm Great! It looks pretty complete, why not rename it to Basic TechDraw Tutorial now?
Please move it or make me an administrator and I'll do it.
Note added, sample file uploaded - good to go.
wf
I was too impatient to put this in the Tutorials page, so I moved it myselfwandererfan wrote: ↑Fri Aug 03, 2018 12:06 am Please move it or make me an administrator and I'll do it.
Page now lives at Basic TechDraw Tutorial.
But I also gave you wiki admin status for the next time, as well as translator. You can now rename, delete and mark pages for translation.
- wandererfan
Merci monsieur.
Now we're in big trouble. Thanks!But I also gave you wiki admin status for the next time, as well as translator. You can now rename, delete and mark pages for translation.
Tutorial added to Tutorials#Technical_Drawings
And I translated it to French! Thanks for this tutorial Wandererfan.
