Adding version to GuiCommand template?
Is it a good idea to add an "Introduced in version" field in a command page infobox?
Yes, let's do it (it's OK for old pages to have an empty field)
7
100%
No, the infobox has enough fields already
0
No votes
Other (please reply what in the topic)
0
No votes
Total votes: 7
NormandC
Post by NormandC »
Hey guys,
I've been playing with the GuiCommand template. That's what generates the infobox in command pages.
The first thing I would like to do is to add an "Introduced in version" field, to indicate in what version of FreeCAD the tool was added.
With this, the "==Notes==" section that a few pages have at the bottom would be unnecessary. I think this would be simpler.
What would happen to all existing pages that do not have a version field? They would look like this:
Realistically we won't be able to fill this new "Version" field for all command pages. I think it's OK to have an empty field.
So what do you guys think? Pinging a few active forum/wiki contributors, but feedback from all is welcome. Thanks!
yorik wrote:
renatorivo wrote:
chrisb wrote:
bejant wrote:
ulrich1a wrote:
HarryGeier wrote:
Re: Adding version to GuiCommand template?
Very good proposal!
Instead of leaving it blank for unknown, is it possible to have a simple dash "-"? The meaning would be something like "Once upon a time" or "long, long time ago" or "in the days when wishes not came true".
NormandC
Post by NormandC »
Sure! And the advantage would be that the field would not be squished.
chrisb wrote: Sun Oct 14, 2018 8:46 pm "in the days when wishes not came true".
LOL :D
ulrich1a
Post by ulrich1a »
Yes, it is ok and does not harm.
Ulrich
renatorivo
Post by renatorivo »
It's OK for me.
NormandC
Post by NormandC »
Thanks guys.
chrisb wrote: Sun Oct 14, 2018 8:46 pm Instead of leaving it blank for unknown, is it possible to have a simple dash "-"?
I realized today, unfortunately, all the existing pages will get the "squished" field. Otherwise, we would need to edit all the pages and add the following to the GuiCommand template:
|Version=-
Which would be an enormous task. But, we could have the dash for all new pages.
NormandC wrote: Mon Oct 15, 2018 4:05 pm I realized today, unfortunately, all the existing pages will get the "squished" field. Otherwise, we would need to edit all the pages and add the following to the GuiCommand template:
|Version=-
Squished is not that bad for existing pages..
bejant
Post by bejant »
I like letting the reader know when a tool / function was added to FreeCAD. It can help someone who is using an old FreeCAD version realize why they might not see a particular tool in their FreeCAD version, so +1 from me (and I did vote).
I think I long ago had added a few simple notes in parenthesis onto a few wiki WB pages (probably Sketcher and Part Design) noting the FreeCAD version into which a particular tool was introduced. Looking at the Sketcher wiki page, it looks like the trend has mostly continued:
https://www.freecadweb.org/wiki/Sketche ... #The_tools
Post by Kunda1 »
NormandC wrote:
Honestly, i think this is smart and professional, I like this proposal. And in theory, this should be really easy to implement if we install this mediawiki extension: https://mediawiki.org/wiki/Extension:MassEditRegex
We could add it to all languages (that we have installed so far).
An aside, it would also make implementing https://forum.freecadweb.org/viewtopic.php?f=21&t=31424 easier
NormandC
Post by NormandC »
I finally changed the template, and also the existing translated templates. I started to manually add the Version parameter to PartDesign command pages that were added in v0.17, and update the translated pages. It's going to be a tedious job...
