python API Power users hub
Discussions about the wiki documentation of FreeCAD and its translation.
vocx
Re: python API Power users hub
Post by vocx »
dulouie wrote: Thu Feb 07, 2019 6:18 pm Any progress for updated doc?
I've build my own doxygen doc with
make DevDoc
but i need a clear python documentation.
How can i generate my own sphinx python doc?
It seems that there isn't enough Python documentation because Doxygen is not very good at displaying Python's docstrings. The Python source code isn't very well documented either. So the source code should be commented much better before trying to generate the documentation.
Previously, Yorik mentioned that at some point they attempted to use Sphinx, but since Doxygen works better for C++, that attempt was sort of abandoned. The Sphinx files are still in the source code https://github.com/FreeCAD/FreeCAD/tree ... Doc/sphinx You may wish to inspect these files to see what can be salvaged.
shadybob
Post by shadybob »
It seems like lately everything is outdated on the power users hub. I'm trying to learn to write scripts, and I recently tried the example line drawing function found here: https://www.freecadweb.org/wiki/Line_drawing_function.
Followed all the directions as best I could (exactly as laid out), but when I do the import example, and then execute example.line() and click my mouse 2 times, I do get a shape in the tree view, but there is no line to be seen. After I hit enter on example.line(), I get this response before clicking any mouse button locations: <exercise.line object at 0x0000021E9473E668>, then I get
>>> # Gui.Selection.addSelection('Unnamed','Shape')
after cllicking the mouse twice. Can anyone tell me why this isn't working?
OS: Windows 10 (10.0)
Version: 0.19.19358 (Git)
Hash: 9e736095187450812e16ff9b92b6839e578f5506
Python version: 3.7.3
Qt version: 5.12.5
Syres
Post by Syres »
shadybob wrote: Tue Feb 11, 2020 9:36 pm after cllicking the mouse twice. Can anyone tell me why this isn't working?
Back in FreeCAD version 0.17 I believe the Part.Line command was changed to Part.LineSegment, therefor change line 17 in exercise.py from:
                l = Part.Line(self.stack[0],self.stack[1])
to:
                l = Part.LineSegment(self.stack[0],self.stack[1])
and it should appear on the screen!!
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19503 (Git)
Hash: bb189d540cb958e63af44347a244188fae217e93
Python version: 3.6.8
Qt version: 5.12.1
shadybob
Post by shadybob »
Syres wrote: Tue Feb 11, 2020 9:55 pm
to:
Thank you! That did the trick! How do we update the wiki page?
vocx
Post by vocx »
shadybob wrote: Tue Feb 11, 2020 10:38 pm Thank you! That did the trick! How do we update the wiki page?
Yes, the power user and developer documentation is quite outdated. How to learn? Follow the documentation, then look at the actual source code of the program. Read the forums, and read the code of macros and external workbenches. It's a messy process, really; there is no straight path to learn.
How to get wiki editing permissions
