not enough description for Create a conic
mad_max
Postby mad_max » Mon Jun 24, 2019 9:02 am
Hello all!
I do the translation and noticed that there is not enough description for Create a conic in the Sketcher Workbench:
https://www.freecadweb.org/wiki/Sketcher_Workbench
Re: not enough description for Create a conic
Postby chrisb » Mon Jun 24, 2019 9:25 pm
What are you missing? If I follow e.g. the link "Ellipse by center" I get to a very detailed page.
The general procedure, if something is wrong or missing is, to fix the English version first and then translate the fixed page.
mad_max
Postby mad_max » Tue Jun 25, 2019 2:41 am
I circled in red a place where there is not enough description, like other tools
Postby chrisb » Tue Jun 25, 2019 4:47 am
I see. How about
"The sketcher provides the following conical sections:"
or a bit longer:
"The sketcher provides the following conical sections. Unlike B-splines they can be used with all sorts of constraints such as tangents, point-on-object, or orthogonal."
mad_max
Postby mad_max » Tue Jun 25, 2019 6:50 am
or a bit longer:
This is fine, thanks!
Postby chrisb » Tue Jun 25, 2019 7:37 am
Glad to see someone working on the wiki!
