Re: pot purri of path issues
Russ4262
Postby Russ4262 » Sat Jul 06, 2019 3:29 am
chrisb wrote:
Thu Jul 04, 2019 7:27 pm
Russ4262 wrote:
Thu Jul 04, 2019 4:11 pm
Usage:
Starting with no existing feature transformations, do the following.
  1. Select the feature(s) you wish to use as the base feature(s) for your `MulitTransformation Feature`. Example: this might be a padded sketch, or a pocketed sketch.
It is not yet quite correct: You cannot start with more than one feature selected, and selecting more than one is a mess:
To add another feature you have to
- click the "Add feature" button in the transform tool
- switch to the tree view
- make the feature you want to add visible. Note: this will hide the previously visible feature
- Click on anything in 3D view.
Add this information to the PartDesign_MultiTransform wiki.
Russ
Postby chrisb » Sat Jul 06, 2019 6:36 am
Thanks for adding it; with all the splitting hassle I forgot to ask if you would do it.
You dropped the easy way for starting such feature, it was present in your post above:
- "Select a feature in the tree and initiate the MultiTransform tool"
or
" ... " points 1 & 2.
