Python code for Units
gomyhr
Postby gomyhr » Sun Jul 14, 2019 7:27 pm
On https://www.freecadweb.org/wiki/Quantit ... _scripting, the code examples start with
from Units import Unit
and
Now, in the python console in FreeCAD (0.18 16117 Appimage, on Ubuntu 14.04.6 LTS 64-bit) those lines do not work. The error message is:
ModuleNotFoundError: No module named 'Units'
So, is the wiki code outdated (I see it had the same form back in 2014) or is something missing from the installation (I can import FreeCAD, numpy, pandas and other modules from the python console)?
bernd
Re: Python code for Units
Postby bernd » Mon Jul 15, 2019 5:38 am
I do not know, but here some working unit code ... https://github.com/FreeCAD/FreeCAD/blob ... #L775-L785
# some unit code **********
from FreeCAD import Units
getattr(Units, 'Pressure')
Units.Pressure
Units.Quantity('25 MPa')
Units.Quantity('25 MPa').getValueAs('Pa')
Units.Quantity('25 MPa').getUserPreferred()[2]
Units.Quantity(25000, Units.Pressure)
Units.Quantity(25000, Units.Pressure).getValueAs('MPa')
Units.Unit('25 MPa')
Units.Unit(-1,1,-2,0,0,0,0,0)
output
Unit: kg/(mm*s^2) (-1,1,-2,0,0,0,0,0) [Pressure]
>>> Units.Pressure
25000 kg/(mm*s^2)
2.5e+07
'MPa'
25000 kg/(mm*s^2)
25
on
OS: Debian GNU/Linux 10 (buster) (KDE/plasma)
Version: 0.19.17360 (Git)
Build type: Unknown
Hash: 348160d4ea970f5f6d0850272c04800c0222c8ba
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
gomyhr
Postby gomyhr » Mon Jul 15, 2019 9:36 pm
Thank you for the working examples. It helped me understand a bit more how the namespace is structured, but I could not quite figure out how to make minimal changes to the wiki code that would work with recent versions (and preferably also work with older versions).
I checked with 0.17, and
works there. I thought this might be related to changes in the python import system between python2 (0.17) and python3 (0.18), and that it could be modified to
from FreeCAD.Units import Unit
which does not work in 0.17 and in 0.18 it gives:
ModuleNotFoundError: No module named 'FreeCAD.Units'
I find it confusing that it says that there is no module named 'FreeCAD.Units', since
>>> FreeCAD.Units
<module 'Units'>
I guess it all boils down to me not knowing how the FreeCAD enviroment is initialized (and how it has changed between 0.17 and 0.18).
uwestoehr
Postby uwestoehr » Sat Nov 30, 2019 6:27 pm
On https://www.freecadweb.org/wiki/Quantit ... _scripting, ...
I see the same. It is no longer possible to use this Python code:
from Units import Unit,Quantity
If somebody could at least give me a pointer where the function Quantity() is no defined, I will update the Wiki page accordingly.
ulrich1a
Postby ulrich1a » Sat Nov 30, 2019 8:21 pm
If somebody could at least give me a pointer where the function Quantity() is now defined, I will update the Wiki page accordingly.
>>> import FreeCAD
>>> FreeCAD.Units
<module 'Units'>
>>> FreeCAD.Units.Unit
<class 'Base.Unit'>
>>> FreeCAD.Units.Quantity
<class 'Base.Quantity'>
The source files are located in src/Base/ beginning with Quantity.
Ulrich
vocx
Postby vocx » Sun Dec 01, 2019 6:13 am
The base modules in FreeCAD are a bit confusing sometimes because some modules are defined in C++ code, but in the Python interpreter they are made available from another namespace.
You have to check the source code occasionally and the Doxygen documentation to see these relationships.
uwestoehr
Postby uwestoehr » Sun Dec 01, 2019 6:47 pm
>>> import FreeCAD
>>> FreeCAD.Units
<module 'Units'>
>>> FreeCAD.Units.Unit
<class 'Base.Unit'>
Many thanks! So Quantity and Unit are now classes and no longer modules. I updated the Wiki Quantity page accordingly (and tested all expressions from here)
