FreeCAD wiki - AddOpenSCADElement page
david69
Postby david69 » Sat Aug 17, 2019 9:53 am
https://www.freecadweb.org/wiki/OpenSCA ... CADElement
this page is talking about how to add an OpenSCAD element and on the right side, the way how to do it.
i'm translating into French and as i am not familiar with that tool, i prefer to check in parallel. here, i don't find neither the icone nor the path under Openscad.
i have installed openscade, reopened freecad but no icons.
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
Locale: French/France (fr_FR)
same thing with
OS: Ubuntu 18.04.3 LTS (LXDE/Lubuntu)
Version: 0.19.
Qt version: 5.9.5
i've got the following message:
OpenSCAD executable not found
Cannot find icon: python
what am i missing? is it an issue with the wiki page? it sounds there is also an issue with the importing icon.
Reason: Fixed title
triplus
Re: openscade wiki
Postby triplus » Sat Aug 17, 2019 10:32 am
Hi @david69.
After you load OpenSCAD workbench open Edit -> Preferences ... and in OpenSCAD section you will be able to set path to the OpenSCAD executable. To install OpenSCAD on Ubuntu this is the method they recommend:
sudo add-apt-repository ppa:openscad/releases
sudo apt-get update
sudo apt-get install openscad
P.S. Path to set is /usr/bin/openscad and FreeCAD restart might be needed after.
david69
Re: FreeCAD wiki - AddOpenSCADElement page
Postby david69 » Sun Aug 18, 2019 7:12 am
hi triplus,
it works even the path is automatically put on both versions.
i still have 2 messages about icons in python prompt and that's an other story. now i can see the icon to add openscad object.
it's a bit disrupting as we see couple icons although openscad is not installed.
i should have more carefully read the wiki. thank you triplus .
triplus
Postby triplus » Sun Aug 18, 2019 1:31 pm
hi triplus,
Good to hear that.
This should hopefully fix the mentioned issue: PR
thank you triplus .
You're welcome.
