[Solved] Rename: Part_CreatePrimitives to Part_Primitives
vocx
Postby vocx » Thu Dec 12, 2019 10:06 pm
The Part_CreatePrimitives page should be renamed to Part_Primitives.
The name of the wiki page must match the sWhatsThis value.
https://github.com/FreeCAD/FreeCAD/blob ... #L213-L225
DEF_STD_CMD_A(CmdPartPrimitives)
CmdPartPrimitives::CmdPartPrimitives()
  :Command("Part_Primitives")
    sAppModule    = "Part";
    sGroup        = QT_TR_NOOP("Part");
    sMenuText     = QT_TR_NOOP("Create primitives...");
    sToolTipText  = QT_TR_NOOP("Creation of parametrized geometric primitives");
    sWhatsThis    = "Part_Primitives";
    sStatusTip    = sToolTipText;
    sPixmap       = "Part_CreatePrimitives";
The icon is called "Part_CreatePrimitives.svg", and the menu text says "Create primitives", however, the command itself is named "Part_Primitives", and thus the wiki page should use this same name.
Reason: Changed to [Solved]
Re: Rename: Part_CreatePrimitives to Part_Primitives
Postby Kunda1 » Tue Feb 18, 2020 2:58 pm
Anyone else in the community able to weigh in before we do this ?
renatorivo
Postby renatorivo » Tue Feb 18, 2020 6:00 pm
Impossible distinguish the icons of Part → CreatePrimitives ... (blue) from those of Part → Primitives (yellow)
Postby Kunda1 » Thu Feb 20, 2020 3:03 pm
impossible to distinguish? what do you mean ?
renatorivo
Postby renatorivo » Thu Feb 20, 2020 5:46 pm
Vox has fixed some things, but the confusion remains. Example: in Part CreatePrimitives click on Box/Cube and this opens Primitives -> Part Box
vocx
Postby vocx » Thu Feb 20, 2020 6:01 pm
But that's exactly what it does. The primitive is created with the Part CreatePrimitives tool (should be named Part Primitives), or directly by pressing the Part Box button. The Part Box button has one icon (yellow), but inside the Part CreatePrimitives dialog, the icon that appears in the blue one.
renatorivo
Postby renatorivo » Thu Feb 20, 2020 6:36 pm
The result is equivalent, but one is labeled Cube, the other Box: one uses standard parameters, the other allows you to enter values; one is activated from Part-> Primitives, the other from Part-> Create primitives .... In the wiki and in the interface for the same object there are yellow icons and blue icons. Maybe programmers want keep the Part-> Primitives shortcut, but I think that's enough to confuse a beginner.
Postby Kunda1 » Wed Feb 26, 2020 11:42 am
So, in conclusion should we rename the page to Part_Primitives or not ?
I'm asking because of https://forum.freecadweb.org/viewtopic.php?f=21&t=43678
but i haven't started the move yet.
renatorivo
Postby renatorivo » Wed Feb 26, 2020 1:05 pm
As Vocx said, we need rename the page, but we also need clarify between Part_Primitives -> Box (Label Box) and Part -> Box (Label Cube)
### Begin command Part_Primitives
>>> from FreeCAD import Base
>>> import Part,PartGui
>>> ### End command Part_Primitives
>>> App.ActiveDocument.addObject("Part::Box","Box")
>>> App.ActiveDocument.Box.Length=10.00
>>> App.ActiveDocument.Box.Width=10.00
>>> App.ActiveDocument.Box.Height=10.00
>>> App.ActiveDocument.Box.Placement=Base.Placement(Base.Vector(0.00,0.00,0.00),Base.Rotation(0.00,0.00,0.00,1.00))
>>> App.ActiveDocument.Box.Label='Box'
>>> App.ActiveDocument.recompute()
>>> Gui.SendMsgToActiveView("ViewFit")
>>> ### Begin command Part_Box
>>> App.ActiveDocument.ActiveObject.Label = "Cube"
>>> ### End command Part_Box
vocx
Postby vocx » Wed Feb 26, 2020 4:13 pm
So, in conclusion should we rename the page to Part_Primitives or not ?...
Yes, obviously.
