the wiki page of Path copy
david69
Postby david69 » Sun Dec 15, 2019 2:02 pm
from that page:
https://www.freecadweb.org/wiki/Path_Copy
there are things which are not matching with the version
OS: Ubuntu 18.04.3 LTS (LXDE/Lubuntu)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
Locale: French/France (fr_FR)
the location says: Path → Path Modification → Copy but I can not find the corresponding in my GUI.
I can not neither find the icon of the wiki page on the GUI.
vocx
Re: the wiki page of Path copy
Postby vocx » Sun Dec 15, 2019 10:44 pm
Didn't you ask this before? There are many obsolete pages about the Path Workbench. In order to really know what exists and what doesn't exist you need to check the source code directly, and cross check with the wiki documentation.
The initialization code of the workbench (InitGui.py) sets up the commands that will be available, together with the toolbars and menus.
https://github.com/FreeCAD/FreeCAD/blob ... py#L87-L98
        # build commands list
        projcmdlist = ["Path_Job", "Path_Post"]
        toolcmdlist = ["Path_Inspect", "Path_Simulator", "Path_ToolLibraryEdit", "Path_SelectLoop", "Path_OpActiveToggle"]
        prepcmdlist = ["Path_Fixture", "Path_Comment", "Path_Stop", "Path_Custom"]
        twodopcmdlist = ["Path_Contour", "Path_Profile_Faces", "Path_Profile_Edges", "Path_Pocket_Shape", "Path_Drilling", "Path_MillFace", "Path_Helix", "Path_Adaptive" ]
        threedopcmdlist = ["Path_Pocket_3D"]
        engravecmdlist = ["Path_Engrave", "Path_Deburr"]
        modcmdlist = ["Path_OperationCopy", "Path_Array", "Path_SimpleCopy" ]
        dressupcmdlist = ["Path_DressupAxisMap", "Path_DressupPathBoundary", "Path_DressupDogbone", "Path_DressupDragKnife", "Path_DressupLeadInOut", "Path_DressupRampEntry", "Path_DressupTag"]
        extracmdlist = []
        #modcmdmore = ["Path_Hop",]
        #remotecmdlist = ["Path_Remote"]
Postby chrisb » Mon Dec 16, 2019 12:11 am
Here I have Menu->Path->Path Modification->Simple Copy
david69
Postby david69 » Mon Dec 16, 2019 10:17 pm
I have asked similar question but it was not for Path. I think I understand what's wrong.
today, we have this wiki page https://www.freecadweb.org/wiki/Path_SimpleCopy
I looked for this icone in the GUI of Freecad and I can not find it:
icone and naming
Capture du 2019-12-16 22-49-59.png (3.3 KiB) Viewed 445 times
Freecad GUI shows:
freecad gui
Capture du 2019-12-16 22-45-30.png (167.74 KiB) Viewed 445 times
so, to what the page https://www.freecadweb.org/wiki/Path_Copy is corresponding to in Freecad?
Vocx, if I refer to the Github you gave, we read that there is an operation called Path_OperationCopy. I looked for it into the wiki and it doesn't exist but we well see it in the GUI. In French, "copier cette operation dans la tache". more, there is no function Path_Copy in Github.
so I think the page https://www.freecadweb.org/wiki/Path_Copy can be rename Path_OperationCopy and describes this missing function. what do you think?
Postby chrisb » Tue Dec 17, 2019 12:13 am
You may ask this in the Path subform, where the Path experts are watching. A link to this topic may be sufficient.
vocx
Postby vocx » Tue Dec 17, 2019 6:50 pm
Yes, this seems to be the solution.
It sounds like in the past many Path functions were renamed, but the wiki documentation was not updated accordingly, so it became out of sync pretty bad.
Also, about the icons, it seems like in the past there were many icons designed, but many of them were not used, and were changed. So, also check this. The real icon is the one that appears on GitHub and on the program. If there is a different icon in the wiki, this may be an old icon that is no longer used.
david69
Postby david69 » Tue Dec 17, 2019 8:32 pm
about icon, not only the wiki, there is also a mess even in the GUI. well, mess is not the correct word: all the function under path->dressup are the same.
about the page, I am not capable to write it. only translating gives headaches in particular when you don't know anything about the topic. the good point, I'm learning.
vocx
Postby vocx » Tue Dec 17, 2019 9:02 pm
Well, I urge you to get familiar with the software before trying to do major edits.
Translating something is not so difficult. We could just use an automated service like Google translate or something like that. The idea is that whoever writes the documentation is also a good user of the software. So, if you want to improve this part, get familiar with it, and then come back to work on the documentation.
