[Solved] Typo correction in "Creating a simple part with PartDesign"
JoshuaCall
Postby JoshuaCall » Tue Dec 17, 2019 4:20 am
Hello, I believe that I have found a typo in the "Creating a simple part with PartDesign" tutorial.
https://www.freecadweb.org/wiki/Creatin ... PartDesign
Where the tutorial says, "Do the same for the horizontal length of the sloped line with another 50 mm vertical distance constraint," I believe that it should instead say "Do the same for the horizontal length of the sloped line with another 50 mm horizontal distance constraint."
I would appreciate it if someone could correct this typo or let me know if I am wrong.
Thanks,
Joshua
Re: Typo correction in "Creating a simple part with PartDesign"
Postby chrisb » Tue Dec 17, 2019 9:33 am
Hi and welcome to the forum!
Thanks for a clear first post including a link to the tutorial. I have corrected the tutorial, please verify.
Postby Kunda1 » Tue Dec 17, 2019 1:23 pm
...also a documentation fix as a first post... :+1: we need more of this :D
Thanks OP.
BTW, @JoshuaCall, please prepend [Solved] to the OP thread title after you confirm the typo fix. Thank you.
JoshuaCall
Re: [Solved] Typo correction in "Creating a simple part with PartDesign"
Postby JoshuaCall » Tue Dec 17, 2019 5:04 pm
Solved; thanks guys.
