[solved] recompute page
david69
Postby david69 » Tue Dec 17, 2019 12:15 pm
as I was translating the tree view wiki page, i noted that [recompute/fr|something_in_French] doesn't work.
if we click on [recompute|recompute], it sends us to https://www.freecadweb.org/wiki/Std_Refresh. we can note for a short while a page "recompute" appearing. something is certainly not properly tuned for that page.
renatorivo
Re: recompute page
Postby renatorivo » Tue Dec 17, 2019 2:50 pm
Recompute must be redirected to Std Refresh.
Created https://www.freecadweb.org/wiki/index.p ... compute/fr see if it works.
vocx
Re: recompute page
Postby vocx » Tue Dec 17, 2019 8:11 pm
This is the problem with using redirections. As it is now, recompute is a redirect to Std_Refresh. They should be used very sparingly.
Instead of [[recompute|recompute]]. We should write [[Std_Refresh|recompute]].
Translating redirects is possible, but it's extra work that we don't want to do. If you find things like this in the wiki, try changing the English page to point to the real page, instead of using a redirect.
A redirection is still useful in the forum. For example, recompute and Std_Refresh will point to the same page.
david69
Re: recompute page
Postby david69 » Tue Dec 17, 2019 8:24 pm
on my translation, I've left [recompute/fr|blala_French] and everything is fixed now on the tree view page.
thanks Renatorivo. it's like a workaround. I agree with Vocx, the best is that writers avoid redirection.
vocx
Re: recompute page
Postby vocx » Tue Dec 17, 2019 9:03 pm
on my translation, I've left [recompute/fr|blala_French] ...
Then don't. Use [[Std_Refresh/fr|blabla_French]].
david69
Re: [solved] recompute page
Postby david69 » Wed Dec 18, 2019 12:16 pm
Vocx I'll do on the French wiki but let imagine that tomorrow a French gives a look and thinks there is a mismatch with the English version. what is his/her reaction?
I'm going to modify the English version too in this way.
vocx
Postby vocx » Wed Dec 18, 2019 6:24 pm
Yes.
(It's already been done.)
david69
Postby david69 » Wed Dec 18, 2019 9:40 pm
thank you Vocx, I was on the point to do it now.
