The idea is first to fine-tune the script so information is formatted as we want. Then how to make it available publicly in another step.
Detecting if a FreeCAD command page has a complete {{GUICommand}} template
Re: Detecting if a FreeCAD command page has a complete {{GUICommand}} template
Of course. Thanks.
Attached a first release of the script (sorry, have to zip it so it's accepted by the forum).
It will :
EDIT : minor fixing in script
It will :
- Display a warning when a 'special' icon is used ('Icon' field used)
- Display a warning when no icon exists ('Empty' field used)
- Display a warning if both 'Icon' & 'Empty' fields are used
- Finally, print 'OK' if all mandatory fields are there, or display 'NOK' if not
- checkGuiCommand.zip
- (761 Bytes) Downloaded 20 times
I'm traveling this week so won't be really available to test. Nevertheless, this is a great solid step in the direction of cleaning up and making the wiki more comprehensive. Cheers!
Well done, my friend.
Dont' worry. It's done when it's done. Enjoy your trip. Just tell me if you need adjustments when you'll have test it.
OK! So, instead of moving forward with bash, lets convert this in to a python script (perhaps with the ability to import pywikibot to actually login and affect change in the future)
There are a lot of false positives due to the script indiscriminately checking wiki pages that wouldn't need to be searched (since they are not commands). The solution I'm thinking for this is creating a file hosted on github that has all the FreeCAD command names (aka pages that would have a {{GuiCommand}} template}, we can then point the script to access said file as an input. Does that make sense?
I'd also propose to have an option to indicate if a template is linted and/or to actually lint it. For example the {{GuiCommand}} markup is preferably expanded and not wrapped all on 1 line, ref: https://forum.freecadweb.org/viewtopic. ... 39#p365395
Could be good to first define a general algorithm (without referring any coding language).
Fair enough.
IHere is a list of all the FC commands (without their translation pages)
https://gist.github.com/luzpaz/08290325 ... 88822d15d1
We can have the script pull https://gist.githubusercontent.com/luzp ... tfile1.txt as the input
