Mediawiki 'Magic Words' in FC wiki (was: Broken Docnav template ?)
mario52
Re: [Solved] Broken Docnav template ?
Postby mario52 » Thu Feb 06, 2020 1:29 pm
hi
is the wiki tools PHP CDf GGG TYTY is complete or he is restrained
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
Postby Kunda1 » Thu Feb 06, 2020 1:42 pm
Can you use different words to ask the question? (language barrier :mrgreen: )
mario52
Postby mario52 » Thu Feb 06, 2020 4:43 pm
hi
peut être qu'il manque quelque-chose dans notre wiki pour faire fonctionner les templates comme {{PAGELANGUAGE}}
mario
Re: Mediawiki 'Magic Words' in FC wiki (was: Broken Docnav template ?)
Postby Kunda1 » Thu Feb 06, 2020 5:26 pm
maybe something is missing in our wiki to make templates like {{PAGELANGUAGE}} work
Yes, good point ;)
Postby Kunda1 » Thu Feb 06, 2020 6:30 pm
@mario52 I figured it out..I think. it needs to be inside <translate> tags
Look at the bottom of https://www.freecadweb.org/wiki/Import_Export
Now look at:
https://www.freecadweb.org/wiki/Import_Export/de
https://www.freecadweb.org/wiki/Import_Export/es
https://www.freecadweb.org/wiki/Import_Export/fr etc...
Postby Kunda1 » Thu Feb 06, 2020 7:13 pm
So the next 2 question are
1. can we use conditional formatting in the {{Workbench Tools navi}} that automagically adds the /{{PAGELANGUAGE}} to each page referenced within the template?
2. how do we use conditional mediawiki formatting to do this?
mario52
Postby mario52 » Thu Feb 06, 2020 9:55 pm
hi
adding it is possible but the translate must be done manually then one template docnav fr, it, ...
for my the + simple:
1 : master page = only english
2 : the browser translate the page in user language (as Google Chrome)
3 : the user FreeCAD translator correct the not good expression and this expression is saved in on dictionary (of this language) in the wiki
et voila
mario
vocx
Postby vocx » Thu Feb 06, 2020 11:13 pm
It could be done theoretically like this.
{{Workbench Tools navi/{{PAGELANGUAGE}}}}
Maybe it can be done with the {{#if}} commands. The exact syntax needs to be checked in MediaWiki. I don't know if it would work in any page or just inside a template.
Something like this. It is basically if-then-else.
{{#if:{{{{{PAGELANGUAGE}}|en}}}
Postby Kunda1 » Sun Feb 16, 2020 2:00 pm
thanks for chiming in vocx, I haven't tested your solution
But..I did dig deeper in to the translation extension docs and found:
https://www.mediawiki.org/wiki/Help:Ext ... p_examples
Specifically:
I'm going to test this soon and see if it works. If so then none of the categories or the {{Userdocnavi}}'s etc.. will need to be in translation tags
Edit: It works!!! 8-) See Import_Export and it's translation pages
vocx
Postby vocx » Sun Feb 16, 2020 4:49 pm
But..I did dig deeper in to the translation extension docs and found:...
Nice. By the way, I'm not sure if the wiki was already moved to the new servers.
I am wondering because that would mean more control over the types of extensions that could be installed, and the entire wiki configuration. Also, it would solve, I think, the problem of locked pages that we've had when they are moved.
