Translations for the FC interface
Re: Translations for the FC interface
Post by Kunda1 »
kaktus wrote: Sun Jun 06, 2021 6:38 pm When each of these tools is activated, the title is displayed in a window (on the blue bar). The problem is that I can't find the translated strings in Crowdin.
Can you show a screenshot of what isn't translated?
It looks like all of these are correct in the source code, for example:
https://github.com/FreeCAD/FreeCAD/blob ... d.cpp#L223
    sToolTipText    = QT_TR_NOOP("Create a new datum point");
The QT_TR_NOOP() function is used to capture strings to translate.
Edit:
The crowdin links that you provided don't show any results for those strings.
kaktus
Post by kaktus »
Kunda1 wrote: Tue Jun 08, 2021 1:08 am ...
of course
the problem is that these translations are not valid, and I am unable to correct them, there are no corresponding strings in Crowdin
Kunda1 wrote: Tue Jun 08, 2021 1:08 am Edit:
I have the same result, so I don't understand the current state of affairs :roll:
In addition, when I switched the Gui language to French, I saw that the "Cancel" and other buttons have their labels translated ... :(
Has anyone checked the number of strings exported to each language to catch differences :?:
wierny padawan mistrza arturromarr
Post by Kunda1 »
kaktus
Post by kaktus »
ok
But there may be more cases like this, and not just in Part Design WB.
I just took care of that workbench first.
:ugeek:
Post by Kunda1 »
Ok, starting to figure out some of the issues. First PR of an upcoming series: https://github.com/FreeCAD/FreeCAD/pull/4850
Evgeniy
Post by Evgeniy »
kaktus wrote: Fri May 21, 2021 9:12 pm [*]
copy FreeCAD_pl.qm ~/.FreeCAD/translations/
Will this work under Windows?
kaktus
Post by kaktus »
I expect not, but a developer would have to confirm this.
Evgeniy
Post by Evgeniy »
kaktus wrote: Mon Aug 23, 2021 7:25 pm I expect not, but a developer would have to confirm this.
Ok, i'm add request to bug tracker https://tracker.freecadweb.org/view.php?id=4733
I need a tool for testing translations in the FreeCAD interface.
There is no point in translating the wiki if everything is not translated in the interface...
and i can't afford Linux any time soon.
Post by Kunda1 »
sgrogan wrote: pinged by pinger macro
sgrogan, any idea if it's possible to test translations locally in the FreeCAD executable on windows?
On Linux we use ~/.FreeCAD/translations
wmayer wrote: pinged by pinger macro
CC @wmayer JIC
yorik wrote: pinged by pinger macro
@yorik do you mind doing a pull/push of translations to master ?
Founder
Post by wmayer »
Kunda1 wrote: Wed Aug 25, 2021 1:55 pm
Yes, the path ~/.FreeCAD/translations is used to check for .qm files.
The paths FreeCAD is looking for are:
  • App.getUserAppDataDir() + "translations"
  • App.getResourceDir() + "translations"
  • :/translations (it's the path of built-in resources)
And recently a fourth path has been added that is controlled by user settings. git commit 719fb95382d59
