This sentence is not correct English. Please stop using it.Invoke the command several ways:
Use:
There are several ways to invoke the command:
Or:
To invoke the command do one of the following:
Don't forget to update your templates as well!
I see, so this page should actually ADD the menu-selection: https://wiki.freecadweb.org/Draft_Annot ... itor#UsageRoy_043 wrote: ↑Thu Jan 14, 2021 5:29 pmI would not be in favor of that. You have to consider that not all commands can be accessed via a menu and a toolbar. Some can only be accessed via a menu (Mesh_RemeshGmsh) and others can be accessed in 4 or 5 different ways (Std_ToggleVisibility). Leaving out the menu option would then be a bit strange IMO.
Thanks for this valuable information. I guess I stay away from this for now. Since I just started making edits, I want to increase the impact of my changes gradually. So, especially no "mass changes" for me.Roy_043 wrote: ↑Thu Jan 14, 2021 6:22 pmYes.
If you are going to implement this for the Draft WB, please note that the layout of the Draft menus has changed. The single Draft menu does not exist anymore in V0.19. Instead there are 4 Draft menus. F.e. Draft → Move should become Modification → Move. And if you add the menu option to the usage section it would make sense to also put the keyboard shortcut option on a separate line.
