In the section you have linked to: |SeeAlso=[[FEM_tutorial/fr|FEM tutoriel]]
We are discussing the GuiCommand model here and the Docnav is part of that page. I gather that you do not like the Docnav on GuiCommand_model page?
https://wiki.freecadweb.org/WikiPages wrote:Note that for the section before the '|' character, the actual link, case is relevant. If your page name is 'Name_of_page' the link will fail if you type 'Name_of_Page' (upper case 'P'). Before the '|' character all spaces should be replaced by underscores ('_'). This is to assist translators using translation software, without the underscores the link would be translated by the software which is undesirable.
Having it after or before the numbering (without special formatting). Having it before may seem a bit strange, but then you know beforehand that you can bail out any time when following the steps.
{{Docnav
|[[Base_PreviousCommand|PreviousCommand]]
|[[Base_NextCommand|NextCommand]]
|[[Workbench_Name|Workbench]]
|IconL= <!--filename of icon with extension (e.g. svg, png)-->
|IconR= <!--filename of icon with extension (e.g. svg, png)-->
|IconC= <!--filename of icon with extension (e.g. svg, png)-->
{{Docnav
|IconL= Base_PreviousCommand.svg
|IconR= Base_NextCommand.svg
|IconC= Workbench_Name.svg
+1Another solution:
